Puffwagon Puff Gold Donating Members 16,282 Member For: 10y 2m 18d Gender: Male Location: South Australia Posted 11/05/18 02:08 PM Share Posted 11/05/18 02:08 PM (edited) On 11/05/2018 at 1:56 PM, Puffwagon said: The ford manual reckons your tcm is probably rooted. Expand But probably isn't if you swapped them over. Edited 11/05/18 02:11 PM by Puffwagon Changed a word or two Link to comment https://www.fordxr6turbo.com/forum/topic/78348-all-things-zf/page/15/#findComment-1657148 Share on other sites More sharing options...
woz84 Member 33 Member For: 11y 5m 20d Gender: Male Posted 11/05/18 02:18 PM Share Posted 11/05/18 02:18 PM Thanks, that document will come in handy. On 11/05/2018 at 2:08 PM, Puffwagon said: But obviously it isn't if you swapped them over. Expand Yea it works fine in the other car. I had some fluid spill out of the convertor when I took it out and thought nothing of it. Just read up that to fill the convertor you hold 2000rpm for 30seconds? Tried that but no change. Link to comment https://www.fordxr6turbo.com/forum/topic/78348-all-things-zf/page/15/#findComment-1657149 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,282 Member For: 10y 2m 18d Gender: Male Location: South Australia Posted 11/05/18 02:59 PM Share Posted 11/05/18 02:59 PM It'd be a good idea to top it up with the correct method but maybe that's not going to help the issue. If the tcm isn't initializing then you'll need to find out why. Is it hardware or software related? I don't know enough about it to recommend a course of action off the top of my head but it can't be too hard to figure out. Maybe other members will have some idea of what's going on. Link to comment https://www.fordxr6turbo.com/forum/topic/78348-all-things-zf/page/15/#findComment-1657150 Share on other sites More sharing options...
woz84 Member 33 Member For: 11y 5m 20d Gender: Male Posted 12/05/18 04:26 AM Share Posted 12/05/18 04:26 AM At first I thought it was software but from my research it might be hardware related. I may have damaged the oil pump alignment tabs on install as I had to pry apart the box from the engine to move the loom that got caught under the coolant temp sensor but I left the converter bolted up to the flex plate when I did this. I have a third spare ZF sitting in my shed so will just install that one or maybe just change the oil pump. Will report back sometime next week. Link to comment https://www.fordxr6turbo.com/forum/topic/78348-all-things-zf/page/15/#findComment-1657178 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,282 Member For: 10y 2m 18d Gender: Male Location: South Australia Posted 12/05/18 04:33 AM Share Posted 12/05/18 04:33 AM It sounds like you'll get it sorted. It'll be interesting to see what is happening, how it happened and if possible how to avoid it in the future. Good luck with it mate. Link to comment https://www.fordxr6turbo.com/forum/topic/78348-all-things-zf/page/15/#findComment-1657179 Share on other sites More sharing options...
woz84 Member 33 Member For: 11y 5m 20d Gender: Male Posted 14/05/18 04:40 PM Share Posted 14/05/18 04:40 PM (edited) Busy day today, reluctantly removed the box and as suspected I fuked the pump ring gear when I had to pry apart the box from the engine to pull the caught loom away. Probably would've noticed the wedged loom if I had a hoist and not doing it on my back with 2 car jacks and bits of timber . Anyway I installed the other zf I had sitting around and the car is running great. Haven't driven it for a while as I rebuilt the turbo and was mucking around with this issue so it's good to be back on the road again. Still need to swap the mechatronics around as it currently has a ZF tune on this TCM that is meant for the other box and I just want the factory tune in mine. Edited 14/05/18 04:47 PM by woz84 1 Link to comment https://www.fordxr6turbo.com/forum/topic/78348-all-things-zf/page/15/#findComment-1657344 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,409 Member For: 17y 6d Gender: Male Location: Melbourne Posted 14/05/18 11:02 PM Share Posted 14/05/18 11:02 PM ouch... good job on finding the issue and at least temporarily resolving it Link to comment https://www.fordxr6turbo.com/forum/topic/78348-all-things-zf/page/15/#findComment-1657346 Share on other sites More sharing options...
woz84 Member 33 Member For: 11y 5m 20d Gender: Male Posted 17/05/18 08:59 AM Share Posted 17/05/18 08:59 AM Mechatronics swapped around so running the standard ZF tune now. Just need my tuner @ jdtuning to re enable the torque tags and should be all good. Link to comment https://www.fordxr6turbo.com/forum/topic/78348-all-things-zf/page/15/#findComment-1657517 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,282 Member For: 10y 2m 18d Gender: Male Location: South Australia Posted 17/05/18 09:01 AM Share Posted 17/05/18 09:01 AM Are you in South Australia? Link to comment https://www.fordxr6turbo.com/forum/topic/78348-all-things-zf/page/15/#findComment-1657518 Share on other sites More sharing options...
woz84 Member 33 Member For: 11y 5m 20d Gender: Male Posted 17/05/18 09:12 AM Share Posted 17/05/18 09:12 AM (edited) yep Edited 17/05/18 09:15 AM by woz84 Link to comment https://www.fordxr6turbo.com/forum/topic/78348-all-things-zf/page/15/#findComment-1657520 Share on other sites More sharing options...
