Very Rough Idle After Surge Tank Install
  • Member For: 16y 4m 20d
Hey guys, I just installed rapid systems 4.5 kit and a plazmaman surge tank in my ba series 1 but now have engine light on and throttle not responding. I did also have battery out for a while before I put the new one in and thought mabe the custom tune I had in the car already my have been removed??
  • Member For: 14y 1m 15d
I fitted an 044 surge tank without a re-tune... Wouldn't the fuel regulator compensate or can't it handle the extra flow? Could it be tested by fitting a fuel pressure gauge after the pump? That might also tell you if it's not making enough pressure.
Edited by riptide
  • Member For: 13y 9m 2d
My afrs weren't too bad after my surge instal, just a little fat, certainly not running rough. Ended up getting them trimmed anyway just to help in the low rpm and cold running areas.
  • Member For: 18y 9m 8d
When I fitted my Process West Surge tabnk and 044 on I had a very rough idle and intermittant stalling. This was caused by the filter (Mesh) in the fuel reg being blocked with crap. As soon as this was fixed, normal idle was achieved.
Just a thought.... Good luck.
Edited by HI PSI
