fuzzyxrt Donating Members 24 Member For: 16y 4m 20d Gender: Male Posted 31/12/11 06:23 AM Share Posted 31/12/11 06:23 AM Hey guys, I just installed rapid systems 4.5 kit and a plazmaman surge tank in my ba series 1 but now have engine light on and throttle not responding. I did also have battery out for a while before I put the new one in and thought mabe the custom tune I had in the car already my have been removed?? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 6d Gender: Male Location: @ my laptop Posted 31/12/11 06:25 AM Share Posted 31/12/11 06:25 AM you can not loose your tune except if the car gets reflashed. Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 4m 11d Gender: Male Posted 31/12/11 06:37 AM Share Posted 31/12/11 06:37 AM Could putting the surge tank in and not retuning the car cause it? as to much fuel. Being pumped in. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 6d Gender: Male Location: @ my laptop Posted 31/12/11 06:48 AM Share Posted 31/12/11 06:48 AM yes, listen to the Panda Link to comment Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 1m 2d Posted 31/12/11 01:49 PM Share Posted 31/12/11 01:49 PM Does the Rapid kit consist of relocating throttle body? If so,is the TPS and TM wiring matched and wired correctly? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 6d Gender: Male Location: Perth Posted 31/12/11 05:52 PM Share Posted 31/12/11 05:52 PM The 044 fuel pump will be causing the injectors to supply to much fuel. Time for a re-tune. Link to comment Share on other sites More sharing options...
riptide Member 733 Member For: 14y 1m 15d Gender: Male Location: Auckland, New Zealand Posted 31/12/11 07:51 PM Share Posted 31/12/11 07:51 PM (edited) I fitted an 044 surge tank without a re-tune... Wouldn't the fuel regulator compensate or can't it handle the extra flow? Could it be tested by fitting a fuel pressure gauge after the pump? That might also tell you if it's not making enough pressure. Edited 31/12/11 07:53 PM by riptide Link to comment Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 1m 23d Posted 31/12/11 09:50 PM Share Posted 31/12/11 09:50 PM A few people mention having installed surge tanks/044's and it still running/being drivable, only made a small difference to afr's.But best bet is to throw it on a dyno.Does it have any dtc's? Link to comment Share on other sites More sharing options...
wa g6et Member 657 Member For: 13y 9m 2d Gender: Male Location: Perth NOR Posted 31/12/11 10:26 PM Share Posted 31/12/11 10:26 PM My afrs weren't too bad after my surge instal, just a little fat, certainly not running rough. Ended up getting them trimmed anyway just to help in the low rpm and cold running areas. Link to comment Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 9m 8d Gender: Male Location: Central Queensland Posted 01/01/12 11:27 AM Share Posted 01/01/12 11:27 AM (edited) When I fitted my Process West Surge tabnk and 044 on I had a very rough idle and intermittant stalling. This was caused by the filter (Mesh) in the fuel reg being blocked with crap. As soon as this was fixed, normal idle was achieved.Just a thought.... Good luck. Edited 01/01/12 11:27 AM by HI PSI Link to comment Share on other sites More sharing options...
