Help? Strange noise!
  • Replies 36
  • You've changed man....
  • Member For: 14y 1m 27d
if I accellerate gently in 2nd Under load its gone, but if I take foot of the accelerator its noisy as when rolling/slowing.
Just drove home from narre to carrum. Everything else seems fine, just this terrible noise.
  • Member For: 16y 3m 1d
Just realised what Adam said. The noise goes away when the clutch is in and thrust bearing is loaded not when it's siting there bouncing around. The bearing is already loose enough with the clutch out. If some of it has been ground away it would be even noisier. that's my theory anyway.
  • Member For: 17y 8m 29d
I was gonna say that but thought it can't be that obvious or someone else would of said it.
^ gunna..
parked, idling in neutral with clutch-
out = noisy
in = quiet
driving under load = quiet
rolling/coasting in low gear = noisy
was not a gradual thing, it was fine on way back from bottleshop then just sat in carpark for a few hours. then when I turned it on to leave the noise was there...
Edited by sad panda
If the noise is mainly there when idling or coasting with foot on clutch (idling at speed) there is a chance your flywheel may be loose
I thought this too but in the vid it showed the noise disappearing and coming back. I was assuming that's with the clutch in then out. Wouldn't loose flywheel be making the noise regardless of the clutch position?
