FPVF6355 Member 128 Member For: 14y 1m 11d Posted 28/12/11 05:53 AM Author Share Posted 28/12/11 05:53 AM I'm just pissed, see how I feel when it's going again.Got the head off, not too bad, but what a bitch to get off.Anyway all inlets are bent, slight dents on the pistons, but no bent rods.Massive carbon build up, which is a good sign of running way too rich. (carbon is very loose comes off easy, so it's recent)Tensioner is in perfect nick.Valves are cheap $360 for a full set of in and out.Ford said they can flash it back to factory specs. (Not the first time they've seen this apparently) big injectors on a rich tune, and higher boost, is typical reason they said.Anyone want to sell a full set of stock injectors for a BA11 F6 ? or swap for a flow matched set of 60lb seimens ? Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 9m 4d Gender: Male Location: Melbourne Posted 28/12/11 05:56 AM Share Posted 28/12/11 05:56 AM Who tuned it mate? Sounds like a bit of a hack job running it way too rich to be safe as they didn't know what they were doing. Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 4m 4d Gender: Male Location: Far north queensland Posted 28/12/11 06:03 AM Share Posted 28/12/11 06:03 AM Anyone want to sell a full set of stock injectors for a BA11 F6 ? or swap for a flow matched set of 60lb seimens ?I have a set - tested and cleaned, I've just got to find them. Link to comment Share on other sites More sharing options...
riptide Member 733 Member For: 14y 1m 12d Gender: Male Location: Auckland, New Zealand Posted 28/12/11 06:14 AM Share Posted 28/12/11 06:14 AM Why don't you swap your injectors for a set of 42lb Bosch's in-case you decide on a bit more power later?... you never know. They will even run without a tune (temporary) and most tuners can tune them easy. Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 9m 4d Gender: Male Location: Melbourne Posted 28/12/11 06:20 AM Share Posted 28/12/11 06:20 AM It still baffles me how anyone tries to tune these cars on standard injectors, hit up any forum and the that's the first thing they tell you. I thought it was common knowledge by now but obviously not. Link to comment Share on other sites More sharing options...
FPVF6355 Member 128 Member For: 14y 1m 11d Posted 28/12/11 06:38 AM Author Share Posted 28/12/11 06:38 AM Who tuned it mate? Sounds like a bit of a hack job running it way too rich to be safe as they didn't know what they were doing.I won't name them, until I'm 100% sure that's the issue.When they tuned it, they did say they needed more fuel, not less and 288 was the most I could get from the stock fule pump.It is possible something else was wrong like the fuel reg, after the tune, so to be fair, until I know for sure, the blame is on me for pushing limits on a car with 150,000 clicks on it. Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 9m 4d Gender: Male Location: Melbourne Posted 28/12/11 06:41 AM Share Posted 28/12/11 06:41 AM Fair enough mate but if it turns out it was there fault...With those sort of kays but it could be anything really. Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 4m 8d Gender: Male Posted 28/12/11 06:43 AM Share Posted 28/12/11 06:43 AM What state at least? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 3d Gender: Male Location: @ my laptop Posted 28/12/11 07:07 AM Share Posted 28/12/11 07:07 AM I really doubt a tune has caused it to hydraulic and bend valves, no matter how rich it was. Link to comment Share on other sites More sharing options...
FPVF6355 Member 128 Member For: 14y 1m 11d Posted 28/12/11 09:00 AM Author Share Posted 28/12/11 09:00 AM Just pulled out the valves, all the seats are perfect, thank F##k.so it's an easy head rebuild.not wrong about soft springs, they are the softest I've seen including little 4 cylinder motors.As for keeping it, I like blowing V8's over 100 clicks, but for most of the time, a V8 is much nicer in traffic. So a stock boss 290 might be a nice change for an old fart, who couldn't be bothered. Link to comment Share on other sites More sharing options...
