Engine Builder Melbourne
Dillz
  • Member For: 15y 1d
fk man, even after your done with the engine, you would still have a heap of money left over ay
  • Member For: 14y 3m 27d
ported head while it's off.
what engine you starting with?
...................Is a ported head really worth the extra coin? maybe on a real hypo motor but don't think it's worth doing.
  • Member For: 15y 3m 23d
it is on a BA - even drop an fg head on, flow better and better cams
  • Member For: 17y 8m 23d
Yep, should get to around 350 for about 25k including car if I play my cards right. Then will need a clutch lol. Would of cost me about 55k in the Limo so bit of a blessing in disguise I guess.
  • Member For: 18y 8m 21d
Hey mate what else am I missing on this list?
H Beam Rods
CP Pistons
Head gasket
Main bearings
Big end bearings
Oil pump gears
Crow valve springs
Balancing
Rings to suit
Engine rebore and recommend line boring
Hot tank clean
Block crack tested
Block deck height checked/machined
Crank Grind or linish
Crack testing crank
Timing chain
Timing chain guides
Timinf Chain Tensioner
Rear Main Oil seal
Timing Case oil seal
Sump gasket
Timing case gaskets
Head Bolts
Head overhaul
Rocker cover gasket
Rocker cover seals for spark plug wells
Cam phaser seals
Inlet manifold gasket
Exhaust manifold gasket
Welsh plugs
If you going to do it, do it properly
I know Micks trying to talk me out of it but isn't most of that stuff rebuilding a blown engine? Like exhaust manifold gasket? How/why would that need to be replaced?
  • Member For: 17y 6m 14d
I dunno I wouldnt be going to that much trouble unless I wanted more the 450 imo. Just keep the g6 and get 330 and u will be happy the lil turbos are fun on the street
not trying to talk you out of it at all, just making sure your eyes are open.
That list is what should go into a proper rebuild, not just a blown engine.
The only difference with building a blown engine and a rebuild is replacing the extra parts which have been damaged by the blow up .I.e block, sump etc.
When building an engine clearances have to be checked sometimes 3 or 4 times until things are done correctly, this means the engine may be assembled 3 or 4 times to get things correct.
It piston to bore clearance is wrong you will end up with a motor that is either noisey or may nip up. If crank clearances are incorrect it may grap a bearing or have low oil pressure and be noisey.
Why would you build a motor and not put a freash timing chain in it, you would kick your self later if the timing chain which may have already done 100000 klms let go and you bent valves and damaged pistons etc
