benjamin New Member 11 Member For: 15y 8m 3d Posted 03/12/13 12:05 PM Share Posted 03/12/13 12:05 PM looks good. Is it simple to remove the speedo cluster? Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/6/#findComment-1443709 Share on other sites More sharing options...
F6Fury Member 135 Member For: 12y 5m 11d Posted 03/12/13 12:18 PM Share Posted 03/12/13 12:18 PM Yes pretty straight foward Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/6/#findComment-1443711 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 27d Gender: Male Posted 22/05/14 10:16 AM Share Posted 22/05/14 10:16 AM Just got my tripple gauge holder from SS inductions today. Pretty impressed I must say. The 2 x autometer cobalts (boost and oil press) I ordered from the US also got here today, so I'm nearly ready to get fitting. For those of you who are after some autometer electrics, just get them on Amazon. Cheapest price anywhere and also crazy cheap for shipping (around $12 from memory). I'm just waiting on a PLX DM-100 touch to come in to make up the final of the three. I figured I'd like to do what I can now, so am going to source some nuts and washers for the cobalts, so I can cut the threads back and fit them to the cups. I've also seen another howto on here which creates a jiffy box for fusing & a pot for the dimming, but was hoping to just piggyback off the stock wiring to keep it much simpler and just use an in-line fuse for each gauge. Sounds like F6Fury's got the pic I'm after, although getting the cluster out sounds like a major PITA. Also that and I'm not super keen on splicing into my nice stock F6 loom What route have most of you guys gone? Jiffy box tapping off the cigarette lighter? I'd also noticed a few of you guys saying that your boost gauge in particular weren't calibrating correctly. In the autometer installation instructions, it states that you need to find a 12V supply that has power even whilst the car is cranking, so that the gauges can correctly calibrate. Without this, the gauge will be off. Only an issue with boost apparently.Also my oil pressure sender only gets about 3 threads down into the speco sandwich plate.... Not sure why, but it looks like the sender is tapered? They're both 1/8" NPT so they should be compatible. Are yours all the same? Cheers,Rob Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/6/#findComment-1473217 Share on other sites More sharing options...
Gussa Donating Members 220 Member For: 14y 3m 2d Gender: Male Location: Gippsland Posted 24/05/14 12:08 AM Author Share Posted 24/05/14 12:08 AM Good work mate.As seen in the first post, I went the Jiffy Box option. Didn't like the idea of loom splicing. Installed them a while ago now and had no dramas.As for the constant supply, I investigated this (can be read on the first page of topic) but found it had the reverse effect (-30 to -15 Vac).My advice to you would be to try the Cig12VDC first, and see what readings you get, if they are consistent to what the car is tuned to, or if stock, around the 10+/- mark, then I would just leave it. If you get readings that are obviously incorrect, maybe look further into a different supply.Off memory I am pretty sure mine was tapered, have you tried it with a spanner to see if it will screw in further? Pretty sure mine went further than 3 threads. Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/6/#findComment-1473516 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 27d Gender: Male Posted 02/06/14 09:33 AM Share Posted 02/06/14 09:33 AM OK. So I fitted gauges and got most of the wiring done (except the sensors) on the weekend. Removal of the ICC want actually not too bad! Wiring was a bitch though, spent ages taping up the gauge loom and placing in the standard cable paths with spiracord. Ended up using the engine start button for constant 12v and earth and then tapped into a brown wire at the top of the ICC for the accessory wire. It was the only wire in the near vicinity that I could use. Only issue now is the dimming as bloody hell the gauges are bright at night!Today I took a look back through this thread and realised that F6FURY was using a brown wire behind the cluster so I decided today after work to pull the cluster out and investigate further. Now using a multimeter, I am unable to find a 12v accessory wire that reduces as you dim the lights/ICC from the dash!? Ideally I'd like to do this so it all dims as one unit, rather than having a separate pot for the 2 gauges only.Obviously this dimming is controlled from dash, so figured I could just tap into this circuit... Appears I was wrong.... or at least I can't find it without a wiring schematic. My question for F6FURY is do your gauges dim with the dash?On a side note, it was a major PITA to try and fit the PLX controller box under the dash. Ended up velcro'ing it in the section to the left of the steering column. I await some feedback before I put all the trims back, lol.Cheers,RobSent from my A500 using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/6/#findComment-1475830 Share on other sites More sharing options...
kyle173 Donating Members 774 Member For: 16y 6m 5d Gender: Male Location: brisbane Posted 24/08/14 09:45 AM Share Posted 24/08/14 09:45 AM Just to confirm mech boost gauge won't fit in a ss pod on a fg? Also is there a way to get trans temp from a zf? Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/6/#findComment-1494819 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 27d Gender: Male Posted 24/08/14 11:52 AM Share Posted 24/08/14 11:52 AM On 24/08/2014 at 9:45 AM, kyle173 said: Just to confirm mech boost gauge won't fit in a ss pod on a fg? Also is there a way to get trans temp from a zf?It will fit but you'll have to cut out the back of the pod to make it fit. Why would you want a mech one anyway? The elec ones work perfectly. Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/6/#findComment-1494871 Share on other sites More sharing options...
RB Snake Donating Members 327 Member For: 11y 4m 14d Gender: Male Location: Perth SOR Posted 24/08/14 12:10 PM Share Posted 24/08/14 12:10 PM Where is the best place to get the Autometer gauges from? I noticed the photos in the OP have disappeared, maybe I'll take picks of all my pick up points and install, it may help some people. Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/6/#findComment-1494877 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 27d Gender: Male Posted 24/08/14 12:19 PM Share Posted 24/08/14 12:19 PM On 24/08/2014 at 12:10 PM, RB Snake said: Where is the best place to get the Autometer gauges from? I noticed the photos in the OP have disappeared, maybe I'll take picks of all my pick up points and install, it may help some people.Got mine from amazon. Was the cheapest I could fine anywhere. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/6/#findComment-1494886 Share on other sites More sharing options...
bandblightfoot Member 183 Member For: 12y 4m 4d Gender: Male Location: Gold Coast Posted 24/08/14 02:18 PM Share Posted 24/08/14 02:18 PM Also got mine off amazon cheapest I could find also. Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/6/#findComment-1494912 Share on other sites More sharing options...
