Stazza_Brendan Donating Members 686 Member For: 15y 6m 25d Gender: Male Location: Mackay QLD Posted 26/08/12 07:22 AM Share Posted 26/08/12 07:22 AM With my gauge holder in BF I wrapped some electrical tape around the gauge. Making it firm to push the gauge into the holder. Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/5/#findComment-1285321 Share on other sites More sharing options...
CHLAXN Donating Members 932 Member For: 16y 11m 14d Gender: Male Location: north QLD Posted 29/09/12 10:09 AM Share Posted 29/09/12 10:09 AM On 19/07/2012 at 11:09 PM, neotim said: I have this exact problem with my boost gauge.. Mine reads about 3vac and boosts to over 20psi.. Could it be due to a faulty sender or the way it was wired up? I'm thinking about ripping it out and replacing it with a mechanical onehi mate did you end sorting it out?? think I may have a faulty sender unit. brought a mechanical gauge but wont fit in the ss pod holder so have to get another electric one. if that does not sort it out I will be ripping the ss pod holder out. Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/5/#findComment-1302247 Share on other sites More sharing options...
Msg6et Member 27 Member For: 12y 9m 28d Gender: Female Posted 09/07/13 01:37 PM Share Posted 09/07/13 01:37 PM Does the sandwich plate have end caps to block 1 of the holes? As I'm only using oil pressure volts and boost Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/5/#findComment-1405329 Share on other sites More sharing options...
brycieboy Member 6 Member For: 12y 3m 17d Gender: Male Location: carrum downs Posted 10/07/13 10:01 AM Share Posted 10/07/13 10:01 AM most sandwich plates come with blanking plugs for the holes.on another note....I have just installed my gauges in my FG... unfortunately I didnt read any threads prior. I had notice most people go with the autometer cobalt gauges so I went out and purchased a mechanical boost gauge.upon leaving the shop I tried to slide it into the cup and it had no sign of fitting. so I went back to return it and the guy assured me it would fit....after getting it home I had to drill the holed for the bolts out slightly as they were out. then it was able to slide the gauge in. after cutting them off I found that the power terminals would not fit either, so they were bent down and trimmed and power wires soldered on.then I realised that I had no chance of fitting the bulky fittings for the boost line in... out came the die grinder and the base got modded.. all good now!I used the grommet in the passenger side footwell (it comes out near the manifold. and I got my power from the spare light plug for the cigirette lighter ( (on the loom just near the cigi plugs)the other 2 gauges are aeroforce.. much easier to install. (plug into obd) this shows the bit that had to be die grinded. its not to noticable. )I will put some black tape over it to hide it oneday Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/5/#findComment-1405501 Share on other sites More sharing options...
Msg6et Member 27 Member For: 12y 9m 28d Gender: Female Posted 17/07/13 02:42 PM Share Posted 17/07/13 02:42 PM so you can run all 3 guages to the 12v plug and its ok? Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/5/#findComment-1407743 Share on other sites More sharing options...
Gussa Donating Members 220 Member For: 14y 3m 2d Gender: Male Location: Gippsland Posted 28/07/13 08:59 AM Author Share Posted 28/07/13 08:59 AM Yeah you can, they draw little. Especially if fitted with LED lights Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/5/#findComment-1410687 Share on other sites More sharing options...
benjamin New Member 11 Member For: 15y 8m 3d Posted 03/12/13 07:23 AM Share Posted 03/12/13 07:23 AM Where do you get the switched power for the gauge lights? Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/5/#findComment-1443655 Share on other sites More sharing options...
F6Fury Member 135 Member For: 12y 5m 11d Posted 03/12/13 11:01 AM Share Posted 03/12/13 11:01 AM Wires are all behind the speedo cluster Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/5/#findComment-1443697 Share on other sites More sharing options...
F6Fury Member 135 Member For: 12y 5m 11d Posted 03/12/13 11:13 AM Share Posted 03/12/13 11:13 AM Here's a pic red/green-12v,black is earth,brown is headlight dim circuit and all works perfect Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/5/#findComment-1443698 Share on other sites More sharing options...
F6Fury Member 135 Member For: 12y 5m 11d Posted 03/12/13 11:26 AM Share Posted 03/12/13 11:26 AM Hope this helps^^^^^^^^^^^^^^ Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/5/#findComment-1443702 Share on other sites More sharing options...
