XRTFG6 Member 97 Member For: 14y 2m 25d Gender: Male Posted 07/02/12 12:56 AM Share Posted 07/02/12 12:56 AM Any updates on best place to get power apart from the cigarette lighter?Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/3/#findComment-1192340 Share on other sites More sharing options...
Gussa Donating Members 220 Member For: 14y 3m 1d Gender: Male Location: Gippsland Posted 07/02/12 05:55 AM Author Share Posted 07/02/12 05:55 AM On 07/02/2012 at 12:56 AM, XRTFG6 said: Any updates on best place to get power apart from the cigarette lighter?Thanks'Seems' like the best place is the Ignition rail on the fuse panel. There should be a spare to use.Haven't had time to do it yet, but I will confirm as soon as I know. Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/3/#findComment-1192478 Share on other sites More sharing options...
XRTFG6 Member 97 Member For: 14y 2m 25d Gender: Male Posted 07/02/12 06:37 AM Share Posted 07/02/12 06:37 AM On 07/02/2012 at 5:55 AM, Gussa said: 'Seems' like the best place is the Ignition rail on the fuse panel. There should be a spare to use.Haven't had time to do it yet, but I will confirm as soon as I know.Ok thanks if I get the chance I'll also have a look Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/3/#findComment-1192506 Share on other sites More sharing options...
JulzC Donating Members 80 Member For: 13y 3m 26d Gender: Male Location: Melbourne Posted 13/03/12 09:36 AM Share Posted 13/03/12 09:36 AM Hey GuysThought a few of you might be interested in this. I put this boost gauge in recently. Its a custom no holes job lol. I mounted it on the pillar and used some double sided foam stuff and zip ties. The wires and vacuum tube then go behind the pillar, down the door rubbers and through the grommet in the footwell. I spliced the +ve wire onto my parker light so the gauge only lights up when I turn my lights on.The position at the moment is a bit high but that's why I havent drilled any holes yet! I will probably move it to sit lower or sit on the dash (near the speaker) Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/3/#findComment-1209523 Share on other sites More sharing options...
Gussa Donating Members 220 Member For: 14y 3m 1d Gender: Male Location: Gippsland Posted 14/03/12 06:10 AM Author Share Posted 14/03/12 06:10 AM Looks the good mate. But better with out the cable ties! Does it vibrate much at higher speeds? Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/3/#findComment-1209776 Share on other sites More sharing options...
JulzC Donating Members 80 Member For: 13y 3m 26d Gender: Male Location: Melbourne Posted 14/03/12 11:24 AM Share Posted 14/03/12 11:24 AM Actually I dont really notice them lol. Not when im driving anyway.No doesn't vibrate at all because of the foam bits I stuck on. Its like double sided tape foam not sure what its called Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/3/#findComment-1209908 Share on other sites More sharing options...
Gonadman2 Member 140 Member For: 18y 6m 12d Gender: Male Location: Perth - WA Posted 15/03/12 05:06 AM Share Posted 15/03/12 05:06 AM Those pillars are about ~$64pr from memory. If you're worried about drilling holes, just go get some new ones to replace them when you're done with your boost gauge. Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/3/#findComment-1210188 Share on other sites More sharing options...
Gussa Donating Members 220 Member For: 14y 3m 1d Gender: Male Location: Gippsland Posted 19/04/12 10:15 AM Author Share Posted 19/04/12 10:15 AM On 07/02/2012 at 5:55 AM, Gussa said: 'Seems' like the best place is the Ignition rail on the fuse panel. There should be a spare to use.Haven't had time to do it yet, but I will confirm as soon as I know.Lads,I gave this spare fuse slot on the "ignition" rail a go. Not a good idea. Had the reverse effect to what was desired. Boost gauge started reading 30VAC at idle and boosted to 15VAC :S :S :S. Long story short, Stick with the +12v DC supply from the back of the cigarette lighter.I can post a pic up if any1 is interested in investigating the ignition supply more.Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/3/#findComment-1224771 Share on other sites More sharing options...
NobleXR6 Donating Members 5 Member For: 13y 5d Gender: Male Location: Noble Park Posted 02/05/12 08:46 AM Share Posted 02/05/12 08:46 AM Great write up. Is it possible to have the gauge lights to dim with the dash/ICC. Can anyone recommend a autolec in Dandenong area Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/3/#findComment-1230664 Share on other sites More sharing options...
CHLAXN Donating Members 932 Member For: 16y 11m 13d Gender: Male Location: north QLD Posted 17/05/12 10:03 AM Share Posted 17/05/12 10:03 AM (edited) I will be looking for a different power source as mine wont calibrate properly on start up cuts out and is out of wack only the boost gauge is affected.. its about 10 out sits on 5vac and boosts to over 30psi lol.. tuner figured out what was happening yesterday when ute was on the dyno. Edited 17/05/12 10:04 AM by CHLAXN Link to comment https://www.fordxr6turbo.com/forum/topic/78203-tutorial-gauge-install/page/3/#findComment-1238833 Share on other sites More sharing options...
