ba brett Member 4 Member For: 14y 10m 11d Posted 14/12/11 09:34 AM Share Posted 14/12/11 09:34 AM Hi there people, I have a ba xr6t, exhaust, bigger inter cooler and injectors on it.I have got a x3 flash tuner to have a bit of a play with it.so far I have only gone from0 to 4 on the global spark (what the hell is global spark?)0 to 6 0 - 2000 rpm timing0 to 2 2000 - 4000 rpm timing0 to 2 4000 - 8000 rpm timingrev limit from 6200 down to 5900 in gear ( I rarely sees about 3200 in its daily drive)rev limit from 6200 down to 3000 in neutral up'd the idle to 750 in gear and driveadded 2% more fuel at wotthis is all changed on the 8 psi tune. im going to run it for a week or so then have a look at the plugs. it has given it a huge kick in the butt, hands down better than the 10 psi gen tune and a even bigger step over the stock tune the car had.before people start up, yes I know you will all say "take it to a tuner" but some comments from people with what they have done right and wrong would be welcome. I have had a search but can't find anything (im not the best with computers but know a little about setting up carby engines). it will go to the tuner some time early next year when funds allow. fuel econ is down to 11- 12l per 100 on the hwy from 13-14 per 100 so its a step in the right direction so far. Link to comment https://www.fordxr6turbo.com/forum/topic/78164-x3-timing-settings/ Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 2m 28d Posted 14/12/11 11:49 AM Share Posted 14/12/11 11:49 AM Wow put those setting back!! 10 degrees below 2000rpm and 6 extra everywhere else is way too much!!!! Link to comment https://www.fordxr6turbo.com/forum/topic/78164-x3-timing-settings/#findComment-1169247 Share on other sites More sharing options...
ba brett Member 4 Member For: 14y 10m 11d Posted 15/12/11 11:21 AM Author Share Posted 15/12/11 11:21 AM (edited) set on 0 its doughy as, its like your driving a car with a stock dizzy curve and a big cam. nothing under 3000. it runs but is slow to rev. nearly stalling in gear at idle no matter where idle is set.I think the gen 8/10 psi tunes are stupidly huge way off and im shocked they are sold as tunes.what do you think I should run?when I pull the plugs I'll try and get some good pics so people can see how its running. Edited 15/12/11 11:27 AM by ba brett Link to comment https://www.fordxr6turbo.com/forum/topic/78164-x3-timing-settings/#findComment-1169550 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 2m 28d Posted 15/12/11 01:12 PM Share Posted 15/12/11 01:12 PM I wouldn't touch anything without an o2 scanner and a dyno if your unsure... These engines are not forgiving. Post up pics of plugs if you like. Plugs are easy enough to read for heat range, pinging and a bit of afr. Link to comment https://www.fordxr6turbo.com/forum/topic/78164-x3-timing-settings/#findComment-1169574 Share on other sites More sharing options...
f6mark Member 2,908 Member For: 14y 2m 2d Gender: Male Posted 15/12/11 07:08 PM Share Posted 15/12/11 07:08 PM sh*t. Link to comment https://www.fordxr6turbo.com/forum/topic/78164-x3-timing-settings/#findComment-1169599 Share on other sites More sharing options...
