They Said It Couldn't Be Done!
Worm
  • 3 weeks later...
  • G666E Turbo!!!
  • Member For: 15y 1m 18d
What offset are your rears? I have +38 19x10.5.
My rims had to get fitted with a 5mm spacer, the problem was the spacer would go off centre and cause a vibration noise.
I had to get bolt on spacers which were min 25mm, now my ears have been pushed out so far they are petruding out from the guard!
I want to sell them and get either 10" or 9.5" rears
They are AXIS Hiros black with chrome lip if any one is interested.
Get hub centric spacers, I had them on mine when I had my 22's they were 5mm and tight as, but no vibration at all... In fact the car drove nicer on the highway than it does now with factory 19's :(
  • Blown Happiness
  • Member For: 15y 9m 6d
Hey guys,
So worms running 20x10.5 +30 and 20x9 +20 and you say the tyre is too small for the rim.
My question is then.... If you changed the offsets to be bigger, say to +35 or +40 rear and +25 front, would that bring the rim inside the gaurd and then allow you to run a tyre that is bigger? or will going a bigger offset just stuff something else up?
I have found a set of rims that are 20x9 for the front and 20x10.5 rear. But for the life of me I can't get a straight answer about the offset or what tyre I need to run.
Any help would be appreciated...
post-35689-0-09698900-1325988188_thumb.j
  • A much better forum
  • Member For: 16y 7m 11d
What car do you have? And didn't I reply to your pm?
Anything less than +25 (ie +35) will hit on the inside upper control arm...
Rear you could run +35 possibly but anything more would hit...
Of you had an FG ute... You could run +25 rear and 295's or 305's on the rear... On the front 255's would be max... 245's don't look stretched IMHO...
  • Blown Happiness
BF Typhoon R-Spec..
So let me know if I have all this right,
20 x 9 +25 for the front would be the go, wheel and tyre would sit inside the gaurd and not hit the control arm? - best tyre would be 255/30/20?
and
20 x 10.5 +35 for the rear. Again I dont want the rim hitting the gaurd or anything on the inside of the rim. - best tyre would be 285/30/20?
Let me know if this is correct.
Cheers for your help.
