Weight Training For Beginners
Kv!
  • Member For: 18y 2m 24d
Ive always struggled with incline bench.. At my peak I was benching 27.5kg on each side,, then incline I was struggling with 17.5kg on each side.. If your having trouble with bench then try incline with dumbells
Edit: read your post again,, didnt realize you said dumbells
Edited by freeze_dk
  • Member For: 16y 13d
Anyone have any suggestions as to why I can't incline barbell bench to save myself? I dumbbell press 32.5 each arm but struggle to push more than 40 total on an incline bench.
Sorry just read it again. Are you comparing flat db press with incline bar?
  • billet turbos and weathered engines dont mix
  • Member For: 12y 7m
You will find your outer upper pec gets smashed during Db press as does your shoulders, because they are independently working to hold weight. Yes, outer chest does get worked on bench but it's the inner now that works more as everything is supported. Do you find you have a weaker inner chest? Almost everyone does, naturally the outer chest is more dominant, atleast that's what I found. Do flys, wide pushups. Squeeze at each rep. It helps.
Oh, unless you have been training for a long while I strongly suggest don't go lower than parallel to your shoulder with anything. Same with knees and squats. Your joints aren't really designed to be hyperextended that way with all that weight to try and deal with.
  • Member For: 18y 4m 1d
I normally do flat bench press. On Wednesday I thought I'll give incline db and decline bench a go. f*ck im still sore today.. My whole chest is sore rather than just the norm, feels great though.. Wasn't doing heavy either, gotta work these exercises in more often.
Whats everyone do mostly, compound or isolated exercises? Ive just started throwing in a set of compound with each bodypart
The Big 3 compound movements, Squats, Bench and Deadlifts should be apart of every routine. These give you a good base and give you alot more strength than isolated movements. Saying that, its good to use variations too.. Leg press, DB press etc.
I use isolated exercises as add-ons to my workouts and to fill in any gaps in the muscle so to speak.
