Hdi Cooler
Brods
  • Replies 31
  • HOON
  • Member For: 14y 7m 24d
retuning soon?
Falcon XR6 EVOLUTION
• Product Code: XR6 EVOLUTION Intercooler Kit • More Info: pdf.jpg mov.jpg stat.jpg • Description
Hybrid XR6 Intercooler Kit
NEW DESIGN, BETTER FLOW, PERFECT FIT
With all HDi front mount intercoolers, we setting the standard for front mount intercooler systems in performance. The ultra high flow and efficiency cooling design set a new level of performance that many other manufacturers can only try to follow.
The new released SIR - X front mount intercooler system, is specifically designed to target the ineffecient loop back design of the factory intercooler. With the special cross fins - high flow core the intercooler kit not only flows exceptionally well but also accommodates perfectly in the limited space within the factory front reinforcement bar and fits neatly within the factory front bumperbar.
By using a longer core length (compared to market trend), rapid throttle response is also enhanced in its design development that means high flow and cooling efficiency with minimal turbo lag. The piping is mandrel bent for improved flow and carefully designed to take the shortest possible route to reduce turbo lag.
DYNO PROVEN 600HP CAPACITY XR6%20Display%20Kit.jpg Please press SIGN UP to get a member offer. signup.gif
  • Member For: 14y 3m 11d
Buying off eBay for 580 delivered so I hope it's genuine:)
Will wack the cooler on first then get a new cat then retune.
Cars running so rich at the moment cooler might lean it out a bit:)
It's an extra 900 that I don't really want to fork out though lol.
Btw is there any clearance differences between BA/F as this cooler doesn't mention bf? They should be the same right?
