  • Inactive Members
  • Member For: 14y 16d
hey guys... I have a BA xr6t currently running stock turbo on a built engine at 20psi. I need to replace the head gasket sooner rather than later as im currently running a copper 1 and it seems that unless you work for NASA theyre pretty hard to get spot on?? suggestions on a good gasket to use?
cheers JET40T
https://www.fordxr6turbo.com/forum/topic/78089-best-head-gasket-to-use/
  • Member For: 15y 7m 26d
Are there MLS gaskets available for the t's? I had them for an alloy headed 13:1 compressioned Expensive Daewoo 383. Sealed well after a bottle of chemi weld :-D
  • Member For: 22y 5m 24d
cheers JET40T
Stock head gasket is good
  • Forged Member
  • Member For: 18y 4m 9d
You could probably find a thinker gasket, but why do you need to?
The falcon already has 8.8:1 comp (iirc) in the turbo motor, so anything less will make it a real dog off boost
  • Member For: 19y 10m 25d
Not really.. the atomic 698 engines have a compression ratio of 8.2, and they are fine around town, with standard cams and cam timing.
Cheers,
Chris.
Edited by Bad Apples
  • 4 months later...
  • Member For: 14y 4m 29d
I might be fitting a head gasket this weekend to an engine I have fitted spool rods to. Everything else is stock (working on a budget) and I will probably run up to 20psi but lower the revs.
My question is should I run the MLS-R 1.3m/m multi-layer head gasket I was sent by mistake or get the one that is $150 cheaper and only a single layer (not genuine)?
I was considering the difference in compression because I am running an NA motor on light boost atm and it goes well and gets good economy.
I also don't want it to blow.
