Brenno Bigbear Montgomery Member 7 Member For: 12y 11m 18d Gender: Male Location: Campbelltown Posted 07/12/11 09:11 AM Share Posted 07/12/11 09:11 AM Hey guys,just brought a 04 xr6 turbo and everytime I go onto bump on the road its sounds like something under the back seats making a noise.. I heard its the axles or something.. someone please help me.. thanks Link to comment Share on other sites More sharing options...
PookeyMaster Donating Members 1,531 Member For: 13y 11m 6d Gender: Male Location: Parramatta, NSW Posted 08/12/11 12:27 AM Share Posted 08/12/11 12:27 AM Is it a creaking noise or a thumping noise?It's probably something in your suspension, but others will have better infor for you. Link to comment Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 15y 8m 29d Gender: Male Posted 08/12/11 02:35 AM Share Posted 08/12/11 02:35 AM or a rattle-like noise like something is loose? Could be worn shock mount bushes. Common problem that annoys newcomers to the used xr market. Link to comment Share on other sites More sharing options...
Brenno Bigbear Montgomery Member 7 Member For: 12y 11m 18d Gender: Male Location: Campbelltown Posted 10/12/11 01:00 PM Author Share Posted 10/12/11 01:00 PM its like a rattle noise.. took it to mechanic they said I need to replace all the diffs and bush peg or something Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 7m 4d Gender: Male Location: Sydney Posted 10/12/11 05:28 PM Share Posted 10/12/11 05:28 PM I think seduced is on the money Link to comment Share on other sites More sharing options...
lambda09a New Member 14 Member For: 12y 2m 3d Posted 23/09/12 03:30 AM Share Posted 23/09/12 03:30 AM I'm wondering if this is the same as the issue I'm having. I have an 04 XR6T and when I go over a bump (even a small bump) I can hear a rattle like sound in the suspension if I have the windows down. I did notice that when I apply the brakes (even ever so slightly) the noise goes away. If it's one thing I hate, its a rattle so any feedback would be appreciated.Cheers Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 7m 4d Gender: Male Location: Sydney Posted 24/09/12 09:26 AM Share Posted 24/09/12 09:26 AM what about the hand brake?Try pulling the handbrake up 2 clicks when going over heaps of those little bumps..I once had those little arms on the inner side of the rear brake rotor that actuates the handbrake tap against the rotor dust shield.Turned out my cable was a little on the loose side allowing the handbrake arm to shake around and tap sh*t. Link to comment Share on other sites More sharing options...
lambda09a New Member 14 Member For: 12y 2m 3d Posted 28/09/12 11:10 AM Share Posted 28/09/12 11:10 AM I tried slowly pulling up the handbrake while driving along and hearing the rattle and I got up to 4 or 5 clicks before I heard a thump from the back (I think as the hand brake engaged suddenly) even though I was only pulling it up very very slowly. I wonder if that whole mechanism is loose. Might jack it up and have a wiggle over the next few days. Link to comment Share on other sites More sharing options...
lambda09a New Member 14 Member For: 12y 2m 3d Posted 29/09/12 06:11 AM Share Posted 29/09/12 06:11 AM I thought I'd go and have a bit of a feel around for any loose parts around the wheels etc. I chocked the front wheel and released the handbrake. I then tried to move the brake calliper and it did move and upon doing so it made a noise at the extremities of the movement. I then proceeded to check the front calliper to see if it had the same movement and it seemed to move even more and make even more noise when I wiggled it. Is this normal? Should there be movement like this from the brake calliper? Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 1m Gender: Male Location: Far north queensland Posted 29/09/12 06:35 AM Share Posted 29/09/12 06:35 AM Diff bush by the sounds of it Link to comment Share on other sites More sharing options...
