nxr06 Donating Members 117 Member For: 20y 10m 14d Posted 29/11/11 11:04 AM Share Posted 29/11/11 11:04 AM Hi, Before I went down the path to find out myself, though I would check here, (if others have similar mods). I have process west twin surge tank kit, fuel rail & ID2000 injectors and curious to what RWKW rating I would starting running of fuel on E85.I have run c16 and 28psi with plenty of fueling left, but given the extra 30% rule for E85, curious see when others have run out????? Cheers Link to comment Share on other sites More sharing options...
XYZ Donating Members 1,171 Member For: 15y 5m 24d Posted 29/11/11 11:18 AM Share Posted 29/11/11 11:18 AM I have made 620rwkw with the same fuel set up as you on E85 and there was still fuel left in it..Typhoon-freak's car from memory made 650rwkw with the same fuel setup before it started running lean.. Link to comment Share on other sites More sharing options...
unclewal Donating Members 583 Member For: 14y 5m 21d Posted 29/11/11 01:02 PM Share Posted 29/11/11 01:02 PM have you got a bigger lift pump to the tank or just the factory intank pump? Link to comment Share on other sites More sharing options...
XYZ Donating Members 1,171 Member For: 15y 5m 24d Posted 29/11/11 10:01 PM Share Posted 29/11/11 10:01 PM have you got a bigger lift pump to the tank or just the factory intank pump?I just have the standard FG one. Link to comment Share on other sites More sharing options...
unclewal Donating Members 583 Member For: 14y 5m 21d Posted 29/11/11 10:34 PM Share Posted 29/11/11 10:34 PM sweet same setup as me then, I got another 200KW of headroom in the fuel system by the look of it. Link to comment Share on other sites More sharing options...
XYZ Donating Members 1,171 Member For: 15y 5m 24d Posted 29/11/11 11:29 PM Share Posted 29/11/11 11:29 PM sweet same setup as me then, I got another 200KW of headroom in the fuel system by the look of it.In saying that, my car has only been in dyno comps and some street use with this tune. If I was planning on some track days I would be upgrading my intake pump as insurance. Last thing you want to see happen is an empty surge tank during extended full throttle driving. Link to comment Share on other sites More sharing options...
NVYDF6 Built F6 & VE SS-V Donating Members 582 Member For: 17y 7m 18d Gender: Male Location: Melb Posted 30/11/11 02:23 AM Share Posted 30/11/11 02:23 AM Good to see some solid results from the same turbo setup I have just bought. I will also be tuning on E85 & I have the PW twin 044 tank aswell as a Walbro intake pump. Link to comment Share on other sites More sharing options...
nxr06 Donating Members 117 Member For: 20y 10m 14d Posted 30/11/11 09:44 AM Author Share Posted 30/11/11 09:44 AM I have made 620rwkw with the same fuel set up as you on E85 and there was still fuel left in it..that's good to know, mine is only BF but I would assume similar rates from the standard pump in BF Vs FG? Link to comment Share on other sites More sharing options...
