sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 1m 2d Gender: Male Location: Far north queensland Posted 10/12/11 05:21 AM Share Posted 10/12/11 05:21 AM ...and even just tightening that front bottom one is a bastard. I could get a uni-joint on there last time but struggled yesterday. do some people use a half moon 14mm ring spanner on it?I put a 1/4 drive scoket, uni then extension in from under the turbo, and near the wheel arch, then a 3/8 to 1/4 reducer and bung the 3/8" drive ratchet on it. Was a dead set kharnt until I worked out that one. Qik1 and I spent almost 2 hours trying bloody everything to get to it after changing turbos one day, in the end I drove round with it out for a few months. Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 15y 11m 11d Gender: Male Posted 10/12/11 07:59 AM Share Posted 10/12/11 07:59 AM sideways: that's how I did it last time, I put some electrical tape on the uni so it wouldnt flop around as much, but for some reason wouldn't want to play when I tried it last weekend. Link to comment Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 13y 10m 18d Posted 11/12/11 01:48 AM Share Posted 11/12/11 01:48 AM No the turbo end has a fine thread. Lock tight won't do anything, remember what we do to things that we need to undo that have lock tight bolts... We hit it with an oxy. I've seen my turbo and manifold glowi g before... I put new studs with a spring washers. Will see his this goesOnly after the manifold end, as I want to get new studs anyway. Old ones shouldn't be reused as they'll have stretched from the heat and coming loose.These should do the trick, m10x1.5 manifold end, and m10x1.25 turbo end, 45mm longhttp://www.ebay.com.au/itm/TURBO-EXHAUST-STUD-NUT-SET-M10-X-1-25-M10-X-1-5-4-PACK-/170532913066?pt=AU_Car_Parts_Accessories&hash=item27b48dbfaa#ht_1118wt_905& these...http://gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=1281&category_id=219&option=com_virtuemart&Itemid=101 Link to comment Share on other sites More sharing options...
LTMFD Member 14 Member For: 13y 3m 9d Posted 13/12/11 03:20 PM Share Posted 13/12/11 03:20 PM http://www.atomicperformanceproducts.com/anchorlox.htmlLooking at this I can't tell if you need the locking bolt kits or stud and locking nut kits for our standard turbos. I'm assuming you need the stud and locking nuts?And are Anchorlox and Stage 8 made by the same company?http://www.stage8.com/dealers/australia.html Link to comment Share on other sites More sharing options...
The Outsider Donating Members 1,205 Member For: 13y 6m 12d Gender: Male Location: Burwood, NSW Posted 13/12/11 11:50 PM Share Posted 13/12/11 11:50 PM http://www.atomicper.../anchorlox.htmlLooking at this I can't tell if you need the locking bolt kits or stud and locking nut kits for our standard turbos. I'm assuming you need the stud and locking nuts?And are Anchorlox and Stage 8 made by the same company?http://www.stage8.co.../australia.htmlaccord to atomic you can use either or?why would you use the studs rather than bolts, im also confused on this issue.have a look at the price of the atomic, its nearly double the stage 8 so I doubt they are the same Link to comment Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 13y 10m 18d Posted 02/02/12 09:03 AM Share Posted 02/02/12 09:03 AM Stage 8 stuff currently on sale at GCG, not a whole lot, but still a sh*tload cheaper than atomic.I ended up getting m10x1.5 studs (both ends, factory is 1.5 manifold, 1.25 turbo end) and the m10x1.5 stage 8 locking nut kit.http://gcg.com.au/index.php?option=com_virtuemart&page=shop.browse&category_id=219&Itemid=101&TreeId=6 Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 1m 2d Gender: Male Location: Far north queensland Posted 02/02/12 09:31 AM Share Posted 02/02/12 09:31 AM why would you use the studs rather than bolts, im also confused on this issue.Studs hold more torque, you tighten the stud first then put a nut on which applies torque in the other direction. Steam pipework requires studs on the flanges.have a look at the price of the atomic, its nearly double the stage 8 so I doubt they are the sameAtomic are inconel, the other GCG are a high tensile alloy. Inconel was inside the last steam turbine I worked on, nuff said. Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 15y 11m 11d Gender: Male Posted 02/02/12 10:32 AM Share Posted 02/02/12 10:32 AM I bought the inconel studs and stage 8 nuts from GCG during the week, but found I will have probably have to remove the turbo and manifold to swap the studs over :( Link to comment Share on other sites More sharing options...
