  • Member For: 17y 2m 28d
Was his car running higher voltage than the norm or?
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/95/#findComment-1261982
  • Member For: 13y 10m 7d
Pick it up in the morning. He said could have went 30-40 more rwkw easily but had to wind it back aboit as it spikes a little as I fitted a new catback exhaust! So next is actuator and wastegate :/ problem is will I need a touch up tune once I send the turbo away and reinstall it? And once again thanks everyone for there input :) love this site.
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/95/#findComment-1261991
  • Member For: 19y 21d
it almost pointless talking power output and various size injectors etc unless you include afr or lambda readings, we all know that a leaner mixture will make more power, but how lean do you want to go
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/95/#findComment-1262008
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 17d
  On 02/07/2012 at 9:14 AM, Henz said:
I'm not anti e85, just you mention 420kw every day but failed to back it up at the track where it counts!
Personally would I be happy with 60s maxed out at 330/15psi? Fuvk no, could make the same on 98 with some SAFETY. But that's personal choice n all that jazz.
I'm not sure abou the Mathe here though, with 60s.
Straight e85 = maxed 330
Straight 98 = maxed 400
And a mix = 420+++++++++
Actually I make the comparison fair, what's the most an sa cars made with 60s?
Ps will 80lbs go 400 on straight united?
I think your confusing me with Ic-er pole +++++++++
my car is the only car that hasnt made the mph but u all know why so quit banging on about that
my ba did 121.4 mph on 327rwkw 50/50 mix u explain that mr back it up
foils car went 127mph on 380rwkw 50/50 mix small turbo
foils car went 450ish on 50/50 mix on multiple dynos mainline aswell
marc17's car went 430rwkw on 50/50 mix went 132 mph
all these cars were on 60 dekas
explain that all proof and mix
shove the +++++++++++++++++++++++ in the ice pole
done a 12 lately?
my fg is the only one to fail the mph due to heat soak on a stock cooler whats your point ?
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/95/#findComment-1262011
as far as your wallet will let u were not modding a prius lets bang it in hard and have fun doing it pushing the envelope is where its at I mean weve seen 9's on ba bottom ends and 480 rwkw out of headsex'es ba doing wicked 10's time to get into it and go alittle
safe if for *beep* like henz
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/95/#findComment-1262016
  On 02/07/2012 at 10:35 AM, 1600dave said:
Could a couple of litres of E85 or Eflex be added to a tankful of 98, to raise the octane and add some safety margin, similar to adding toluene??
yeh smash 25 ltrs in and get all the timing u want this is called a mix
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/95/#findComment-1262017
