E85
  • Member For: 18y 8m 3d
so if the % is off what do you do to get it back to 85 as per your tune?
pull over drain tank and refill?
drive it off boost, change fuel or flash another tune in it to suit the fuel, your choice, pick one
  • Throbbing Member
  • Member For: 15y 11m 25d
What sort of fittings did you use on it mick, bit hard to see in the pic, standard ford lines just push onto the sensor?
  • Member For: 16y 2m 8d
If the reading is high then put some 98 in it.
If the reading is low drive off boost to your nearest dan murphys.
  • Resident idiot.
  • Member For: 14y 4m 10d
so if the reading is off seems like a pita to me to get it to where it should be. ie 85.
Have any of the readings people have been taking been off so far? (from united anyway)
  • Member For: 16y 10m 10d
Jetsnot said there not. So they mustn't be.
  • Like 2
  • Throbbing Member
all the readings I have taken from croydon, balwyn and altona north have been between 88-90. New pump is going in at eltham as I type this, so I'll test that when its all finished.
