E85
  • Member For: 17y 6m 20d
My E85 tune is a drag tune only as I had limited time on the dyno, so Headsex will be adding alot more timing next week at cruise level, to decrease my fuel consumption.
  • Resident idiot.
  • Member For: 14y 3m 25d
cbf'd switching tunes? Its harder to fill up the tank than to switch tunes. How much driving a you really going to do per day that you couldnt fond a united if you really had too. If you couldnt though I wouldn't be concerned switching back to 98. Surely if it's low enough to fill then there can't be that much and if anything it will make your 98 better
The whole 30% more fuel use is a bit off, Maybe under full load yes but for day to day I think I came out a little worse but not really noticeable. So much more response and power off boost that I didn't need to drive as hard.
  • Like 3
  • Member For: 12y 8m 8d
I said UP TO 30% not 30% flat.... and those figures are right it will vary on what type of tune you have but around those figures is spot on I run E85 24/7 and my L/100 is 16.8 atm I know if I start using the 98 ron it will drop to high 12.0L/100
  • RNS10S
  • Member For: 18y 4m 29d
Where are you getting the 16.8 L/100, of the ICC or are you calculating it based on your fill ups?
I get between 350 - 400 a tank but myy ICC still shows me 13.7 L/100
you need up to 30% more fuel when on E85, go to wiki E85 it says it there, the E85 website here in Australia it says it there as well, E85 has less energy so you use more fuel I dont post to start arguments go check it out thnx
  • Turboless
  • Member For: 13y 10m 18d
Lol just me but I'd never use wiki as a reference in an argument. Even I could edit that info haha. But good stuff on your research nonetheless mate :)
  • Member For: 12y 10m 16d
Google doesn't lie.. Try this:
Step 1: google 'urban dictionary'
Step 2: search 'ham sandwich'
Not what I thought a ham sandwich was....
from urban dictionary..
ham sandwich 16 up, 25 down
When you approach a sleeping person, and gently lower your buttocks over their nasal cavity, sealing off air flow. When they open their mouth, gasping for air, strategically lower your *beep* into their mouth. Upon restriction of breathing, they will regurgitate the *beep*.
You have successfully performed a ham sandwich.
My name is John Ward Doucette from Sault Ste. Marie and I always pretend to fall asleep so I can get a ham sandwich from my closest buddies.
lol...
  • Like 5
