  • Member For: 22y 3m 25d
Hey xr6t_ute
Forgot to mention that even thoe its a Ba it has a been converted to a zf 6 speed auto with 3.7 diff gears so the 6 speed definatly helps with fuel consumption even thoe the diff gears are changed to reduce lagg on the 51r and the rpm sits slightly higher when cruising around . When the car was running 100 ron with a 4 speed it was less fuel efficient than now even thoe it had 200rwkw less.The cost involved in running a car with this much power is irelevent just some info with specks and fuel consumption for other readers wanting the perfect car to go cruising with friends have the option to take the family and enjoy the car without stoping for fuel every hour that is why I could never run a 2 speed glide in a car like this because the for me the positives outway the negatives between the two trans for what I intend in doing with the car. Cheers.
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/4/#findComment-1183475
  • You've changed man....
  • Member For: 14y 5m 13d
The United near my place is selling e85 again. I thought it was over $2 a litre ?
The guy told me its 10c cheaper than 95.
Also is it true that united change it from summer to winter requiring you to run 2 different tunes?
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/4/#findComment-1183477
  • Member For: 17y 11m 15d
Summer mix is e85, winter mix is e75, I personally would run it up on a dyno to check the differences in the tune and make your assumptions wether to run 2 tunes or not
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/4/#findComment-1183562
  On 19/01/2012 at 7:26 PM, FPVPSI said:
Hey xr6t_ute
I'm right behind you on that one, I can't justify a two speed if u can have the best of both worlds, looks like Simon has done a real good job with your goals.
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/4/#findComment-1183566
  On 19/01/2012 at 11:55 PM, ratter said:
Which united Ben, Thompson Rd?
Yer carrum/patterson lakes.
I drive past it twice a day.
Has me pondering. Didnt really consider it till Henz said when we drove past.
I also heard Caltex doesnt alter the mix summer/winter
Edited by STAINLESS
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/4/#findComment-1183567
  • Member For: 22y 2m 10d
You have not mentioned what cars/engines these were. Most importantly was it a late model Ford 6cyl???
  On 17/01/2012 at 5:19 PM, FIERCE said:
As I said before The Valve stem seals were eaten away, Valve guides were worn... In Short terms, Our company vehicles were showing wear at 50000 klm, of what you should see at 250000 klm. Now as doing some research I do know certain engines are certified for this High Ethanol Percentile Fuel mix. And Some are still yet to make the required upgrades to there engines. Im pretty sure its nothing more than when we used to all run on Leaded fuel, Converting to an Unleaded fuel we all needed an additive of some sort.
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/4/#findComment-1183589
  • Resident idiot.
  • Member For: 14y 8m 20d
Hallam united is selling e85 now, I was talking to a guy tonight who has a pretty much stock F6 (injectors and fuel pump) he's got 340 with e85.
Now that it's getting easier to find I'm keen to try it. Even make a power tune for e85 and an everyday less power/strain tune.
  • Like 2
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/4/#findComment-1184028
Its 1.34 a ltr if anyone's curious about the price
https://www.fordxr6turbo.com/forum/topic/77949-e85/page/4/#findComment-1184943
