  • Member For: 19y 7m 26d
KPM1500
FG Turbo models $834
BA-BF Turbo models $930
Direct replacement fit.
Includes tuning data, 3 Year Warranty , Tech support.
Edited by KPM Motorsport
  • Member For: 19y 11m 9d
Mick, raise your fuel pressure if you have the pump capacity and need a tad more. Go out and datalog your pulsewidth and RPM and I'll tell you exactly when they're going to be out of flow. Otherwise you know my response!
Those Fivo-o are probably the 0 280 158 040 injector. ID told informed me they're a factory two stroke Polaris injector from a snow mobile!
  • Member For: 18y 3m 11d
Thanks Toads,
Was just curious that's all. Considering I've already got the stubby ID's Im assuming I could use the FG injectors and the adapters I have now would fit, that makes the 1500's from KPM a nice option. I do like the ID's but I would rather have something that is rated for the Ethanol and that is why I was looking at the ID 1300's. Will do some logging and see where they stand now. I still run that Lucas ethanol additive even with the united pump E85, been running it for over 18 months straight without issue so far, Still stock rubber lines from between the sender and the surge. I replaced the intank stuff when I did the pump, and upgraded from surge to rail when I did the aftermarke reg and fuel rail.
  • Bronze Donating Members
  • Member For: 13y 10m 27d
Nah there not, there modified by five o. Part number is 0280 158 117 but then there modified again Edited by gaz097
  • 2 weeks later...
  • Member For: 22y 2m 18d
Just checked my E85 fuel bill for the month. $642 which equals about $160 a week. Would normally spend about $100 to $120 on 98. The read out is about 26l/100km, about 270 per tank.
I have tried tuning it lean (up to 18+:1 in petrol ratios) but does not seem to give much benefit but does like a lean cruise ratio though.
Going back to 98 as a bit tired of going to the pump all the time.
Have managed good cold starts with these cold mornings here in Perth lately. Within 2 to 3 cranks. Its at 0.5 cranking lambda for me and its about 12.5 air/fuel ratio (petrol) once started. Just juggle the numbers cause your tune will influence what lambda you get at crank and cold start but the point is you can still get good/reasonable starts on 2 degree mornings with E85.
However I did find on long constant speed trips it can be pretty good on fuel, just very thirsty on stop start driving
Edited by turbotrana
  • Member For: 12y 2m 14d
Hey trana check your inbox on the HP Tuner forum
That is a SIN.....E85forlyf! lol
  • Dropping a turd
  • Member For: 17y 7m 21d
that's just one of the reasons I didnt go E85.
Dont go back to 98. Use P100
