turbotrana Member 2,586 Member For: 22y 2m 17d Gender: Male Posted 10/06/14 05:58 AM Share Posted 10/06/14 05:58 AM I am planning to do that but you have to set up the air fuel ratio meters on a separate battery supply to see the first few seconds of the air/fuel ratio as the start up interferes with the meters on startup.I will wait till its about 5 deg mornings in Perth before I start doing this. Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/221/#findComment-1477526 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 2m 17d Gender: Male Posted 10/06/14 07:28 AM Share Posted 10/06/14 07:28 AM From a Delphi website:Ask about improper E85 usage.Although all modern vehicles now run off of fuel that contains some ethanol, E85 is not compatible for the vast majority of today’s vehicle market. With prices that are typically lower than gasoline, drivers often fill up on this cheaper alternative without realizing or considering the damage it may do to their vehicle. Essentially all alcohol, E85 is a drying substance and is very hard on fuel pumps and seals when used in vehicles not designed for E85 fuel, and can lead to serious malfunction. Premature failure, fewer MPG and reduced power could be indicators of improper ethanol use, signaling that a repair needs to be done. Be sure to ask the customer with these symptoms if they have recently used E85. Without proper diagnosis, this can result in unnecessary comebacks if the E85 use continues.Check fuel level – and make sure your customer does too.Most people have driven on empty plenty of times without a second thought. But, driving on “E” can contribute to fuel pump malfunctions. It’s your job to make sure your customers know why. Fuel cools the pump motor, so when drivers are running on little to no gas, overheating can result. Besides heat damage, running a vehicle on low fuel causes the pump to pull the dirtiest fuel from the bottom of the tank and possibly cause increased wear. This can destroy or shorten the life of an electric pump. Unfortunately, there are no visual indicators of overheating. A pump in this condition can only be identified by performing an electrical check. It will either be bound, not turning, or show as an open circuit. Overheating will cause it to fail. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/221/#findComment-1477559 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 11m 9d Gender: Male Location: OZ Posted 11/06/14 04:18 AM Share Posted 11/06/14 04:18 AM Mine is cranking fine in sub 10 degrees C. No different to hot start....even with the cams. I'm at ~0.6X lambda. I'm still using a 0.8mm gap, 6 rated plug.What J did note was that when my fuel relay sh*t itself and was running off the intank the cranking was quite delayed. Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/221/#findComment-1477769 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 17d Gender: Male Location: Adelaide Posted 11/06/14 08:23 AM Share Posted 11/06/14 08:23 AM Really lol never would of guessed that Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/221/#findComment-1477838 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 11m 9d Gender: Male Location: OZ Posted 11/06/14 09:57 AM Share Posted 11/06/14 09:57 AM FYI.....excessive crank / delayed fire is quite common with just intank Walbro running. I'm talking on PULP too. When I first got my car tuned by XFT and a Walbro intank was fitted, the first thing I noticed was that it took several more cranks to fire. Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/221/#findComment-1477861 Share on other sites More sharing options...
45T-XR Donating Members 417 Member For: 18y 3m 10d Gender: Male Location: Gladstone, Queensland Posted 12/06/14 05:37 AM Share Posted 12/06/14 05:37 AM On 10/06/2014 at 5:58 AM, turbotrana said: I am planning to do that but you have to set up the air fuel ratio meters on a separate battery supply to see the first few seconds of the air/fuel ratio as the start up interferes with the meters on startup.I will wait till its about 5 deg mornings in Perth before I start doing this.I had to do the same thing. Instead of configuring my wideband that is permanantly mounted in the car to run to constant power, I just used the LM-2 with a female 12V socket to Alligator clamp adapter. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/221/#findComment-1477987 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 11m 9d Gender: Male Location: OZ Posted 15/06/14 11:15 AM Share Posted 15/06/14 11:15 AM e85 cold start. Doesn't get much colder in Perth. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/221/#findComment-1478681 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 2m 14d Gender: Male Location: Liverpool Posted 15/06/14 11:30 AM Share Posted 15/06/14 11:30 AM If the injector scaling, and voltages are out could that contribute to a poor cold start? Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/221/#findComment-1478685 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 17d Gender: Male Location: Adelaide Posted 15/06/14 11:39 AM Share Posted 15/06/14 11:39 AM 150% Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/221/#findComment-1478688 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 2m 14d Gender: Male Location: Liverpool Posted 15/06/14 11:40 AM Share Posted 15/06/14 11:40 AM Makes sense Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/221/#findComment-1478689 Share on other sites More sharing options...
