Kosij Donating Members 2,045 Member For: 13y 10m 7d Gender: Male Posted 09/05/14 03:13 AM Share Posted 09/05/14 03:13 AM Cold start no priming - Big difference so if fuel pressure doesn't play a role what is? Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/213/#findComment-1470578 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 2m 14d Gender: Male Location: Liverpool Posted 09/05/14 05:28 AM Share Posted 09/05/14 05:28 AM I'd say the initial fuel pressure has something to do with it, but it doesn't take that long to build pressure, it should almost be instant Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/213/#findComment-1470608 Share on other sites More sharing options...
10SECN Member 516 Member For: 12y 1m 15d Gender: Male Location: west hoxton Posted 09/05/14 05:30 AM Share Posted 09/05/14 05:30 AM mine takes about 3 to 5 seconds .... atleast u know u have oil pressure once its fired .... I can live with the slow starts 1 Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/213/#findComment-1470609 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 1m 27d Gender: Male Location: Sydney Posted 09/05/14 05:34 AM Share Posted 09/05/14 05:34 AM (edited) On 09/05/2014 at 3:13 AM, Kosij said: Cold start no priming - http://youtu.be/ETqjm8OENRABig difference so if fuel pressure doesn't play a role what is?Fark u wouldn't wanna have a sh*t battery! Edited 09/05/14 05:34 AM by Kroozin Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/213/#findComment-1470610 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 10m 7d Gender: Male Posted 09/05/14 05:36 AM Share Posted 09/05/14 05:36 AM Yellow top in the boot has had a hard life but lives on. As I said before used to start Instanlty and I was amazed with it. Now with another 044 & no check valve this is what happens. Will add another check valve and see what happens 1 Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/213/#findComment-1470611 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 2m 18d Gender: Male Posted 09/05/14 07:43 AM Share Posted 09/05/14 07:43 AM Kosij, You may be onto to something. Definately will try that technique. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/213/#findComment-1470636 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 10m 27d Posted 10/05/14 08:21 AM Share Posted 10/05/14 08:21 AM Yeah that's a f*cked start . And does sound like low fuel pressure. Mine does a similar thing. If I hit the key when my fuel pump is buzzing it will start on the first crank. If I prime it twice it will start first crank. If I prime in once it will spin over 3 or 4 times. That's only on 98 as well. Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/213/#findComment-1470804 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 21d Gender: Male Location: @ my laptop Posted 10/05/14 09:17 AM Share Posted 10/05/14 09:17 AM cold starts in Tassy are going to be worse than cold starts in Surfers with E85, so maybe you guys should be mentioning what starting temps you are talking about Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/213/#findComment-1470814 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 2m 14d Gender: Male Location: Liverpool Posted 10/05/14 09:36 AM Share Posted 10/05/14 09:36 AM As said, I have issues when IAT's are less then 15 degrees, and ECT around 20 degrees... Any tips you would like to share ratter? Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/213/#findComment-1470815 Share on other sites More sharing options...
GUN-808 Member 251 Member For: 11y 7m 7d Gender: Male Location: Gold Coast Posted 10/05/14 11:28 AM Share Posted 10/05/14 11:28 AM On 09/05/2014 at 12:46 AM, turbotrana said: I was reading up on cold starting and E85 last nignt and its just the nature of the fuel.However there seem to be some who don't have an issue so it seems some tuners have it sussed.It seems you just need heaps of fuel on cold starts. I am just going to experiement making it richer and richer.Its got nothing to do with fuel pressure.Spot on..My old car with e85 ran 2x 044s and a surgie without check valves..It ALWAYS showed 50psi on the gauge in Fuel Pressure so I can guarantee it not pressure related.. its just the fuel..some tuners just write it off and say the same but u CAN get on top of it if u fiddle with crank and cold start options..I had 1 reputable tuner tune it and it was a bitch on start and he just blamed the fuel.. I told my new tuner this and we pretty much added a heap of fuel in the dead cold crank setting to sort it..(im not sure about the setting in a X-cal sorry so not sure how to do this) but in Microtech theres a % mixture at different water temps in regards to cold start enrichment.. so when it changes to the next temperature range it returns to the normal pattern which was usually about 30secs.. theres a big difference needed in this setting in regards to the 98 graph.. sorry if that's confusing but im not sure how to relate it to the Ford tuning.. Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/213/#findComment-1470827 Share on other sites More sharing options...
