  • RNS10S
  • Member For: 18y 9m 23d
  On 03/12/2013 at 10:21 PM, Paulie2256 said:
Just buy a GM branded sensor and change the plug on the zeitronix unit to fit.
Should be back to normal again.
Was going to do that Paulie, but the GM sensor is chunky, the flow through sensor can be mounted out of sight and is a much cleaner install.
  • Member For: 14y 8m 19d
Is this on the passenger side rail near the fuel filter? or near the tank? Trying to figure out where to locate mine
  • RNS10S
  On 03/12/2013 at 10:29 PM, Paulie2256 said:
yeah that is nicer. I wonder if the haltech one is any better being the same shape as the zeitronix
I think they are all made by Continental Paulie.
Not sure if they read the same.
  • 2 weeks later...
  • Menace
  • Member For: 14y 1m 18d
  On 06/11/2013 at 3:17 AM, rednose said:
I use Lucas Safeguard, designed for ethanlo use.
I use it every 3-4 tanks and car runs silky smooth
Safeguard™ Ethanol Fuel Conditioner with Stabilizers
Lucas Safeguard™ Ethanol Fuel Conditioner with Stabilizers was developed to
specifically address issues associated with using ethanol based fuels.
This applies to E-10, E-15, E-85, pure ethanol and any mixtures in between including gasoline.
Our Product is completely soluble in all ethanol fuels and will not harm filters.
Lucas Safeguard™ Ethanol Fuel Conditioner with Stabilizers contains effective additives
to prevent rust and corrosion associated with the use of ethanol fuels.
Key Benefits:
• Cleans injectors, valve seats, combustion chambers and other critical fuel components
• Stabilizes fuel and prevents varnish & gum formation in ethanol and gasoline
• Combats deposits and protects your engine oil lubricants from the
harmful effects of alcohol combustion
Safeguard™ treats up to 80 gallons of ethanol fuel.
One ounce treats five gallons of ethanol fuel.
Our new 5.25 oz bottle treats up to 25 gallons of ethanol fuel.
Recommended for use in automobile and marine applications.
NOT RECOMMENDED FOR DIESEL APPLICATIONS
Throwing a wild card here I know but... (Lol)
I saw the rotary boys at the servo using castor oil to help with lubrication, etc.
How would this go with our T's?
Or even a dash of 2t?
  • Bronze Donating Members
  • Member For: 12y 4m 14d
I saw this in super cheap the other day I think its around $10-$11 per bottle and treats 95 litres , apparently you can use it with e85 going by their web site. Its an upper cylinder lube and injector cleaner. Still not sure how upper cylinder lube and ethanol mix but I guess a small amount in a full tank maybe its not an issue.
post-56158-0-32473200-1387090210_thumb.ppost-56158-0-15839600-1387090255_thumb.p
