rednose RNS10S Donating Members 2,229 Member For: 18y 3m 26d Gender: Male Posted 12/09/13 11:34 PM Share Posted 12/09/13 11:34 PM I use the Lucas one Link to comment Share on other sites More sharing options...
ford number 1 Donating Members 602 Member For: 20y 3m 13d Gender: Male Location: N/W Sydney Posted 13/09/13 10:57 AM Share Posted 13/09/13 10:57 AM I use the Lucas oneIs it recommended to run this with E-Flex as well?? Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 8m 12d Gender: Male Posted 13/09/13 11:13 AM Share Posted 13/09/13 11:13 AM From limited reading it seems high ethanol is a bit hard on the valve and seats. Saw a pic of one head (used in a marine engine with E15) where the valves were all cracked.Maybe ethanol fuels need more upper cylinder lubricant mixed in from the refinery.Has anyone stripped a high km, high ethanol engine of late. Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 3m 26d Gender: Male Posted 13/09/13 11:52 AM Share Posted 13/09/13 11:52 AM Is it recommended to run this with E-Flex as well??It is recommended for all ethanol fuels 1 Link to comment Share on other sites More sharing options...
Justa6 Member 214 Member For: 15y 6m 22d Posted 13/09/13 09:42 PM Share Posted 13/09/13 09:42 PM (edited) Heard of injectors stuffing up when left sit. If my ute was not to be driven for quite a few months, would it be better to drain the cell and try to run 98 in it for a bit?It will run rich as, foul the plugs, but might be better for the injectors?Or is there something better. Edited 13/09/13 09:45 PM by Justa6 Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 8m 12d Gender: Male Posted 13/09/13 11:27 PM Share Posted 13/09/13 11:27 PM I was reading about ethanol fuels and small perol engines like whipper snippers, lawnmowers, outboard mtrs etc.Most of these small engines are not ethanol compliant and if left to sit with ethanol fuel will just glug up from dissolved rubber. In USA they only have ethanol fuels now so its a big problem. Just don't use on these small engines.Newer cars are more ethanol compliant but I still think they are a bit hard on everything they touch, so if you don't drive it often you may be better with non ethanol fuel. Link to comment Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 3m Gender: Male Location: sydney Posted 13/09/13 11:39 PM Share Posted 13/09/13 11:39 PM how much do you put in and do you do it every re-fill ? Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 3m 26d Gender: Male Posted 14/09/13 01:44 AM Share Posted 14/09/13 01:44 AM 60ml in a full tank, I only do it roughly every 4 or 5 tanks. Link to comment Share on other sites More sharing options...
G6ET8U Playing with Sports Bikes... Silver Donating Members 1,927 Member For: 19y 1m 13d Gender: Male Location: Whistling, GTX. Posted 14/09/13 08:50 AM Share Posted 14/09/13 08:50 AM 2 044's with a surge tank or swap the 1 O44 I already have out for an Aeromotive A1000?Clearly keep surge tank....Jack Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 8m 22d Gender: Male Location: Vic Posted 14/09/13 09:29 AM Share Posted 14/09/13 09:29 AM Not many good reviews for the 1000. Fit a second 044 or flog it off for the new PW one. 1 Link to comment Share on other sites More sharing options...
