Bellato Donating Members 2,713 Member For: 14y 3m 12d Posted 23/04/13 12:06 PM Share Posted 23/04/13 12:06 PM Have you tested your eflex at all rednose? As mentioned its been tested between e60 and e80 here in the ACT. I'd imagine the tune would have to be backed off quite a bit to compensate for the change in ethanol content? Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 9m 10d Gender: Male Location: Sydney Posted 23/04/13 07:20 PM Share Posted 23/04/13 07:20 PM I have been using eflex for almost 2 years, no issues.Surely over the 2 years with more than 70 passes on eflex if there was a problem with it it would have revealed itself.Sorry guys but I really cannot fault this fuel.Don't know why there is no love for eflex especially when most of the guys having problems or issues with ethanol that I am reading about are using Uniteds E85.This is why I went back to eflex again. I ended up with black powder chit that destroyed my fuel pump, reg., blocked and in inj. and had to pull out my fuel tank (cradle out) to get it flushed.It may have been the particular servo who knows but... I have had no dramas with eflex to date (touch wood) and will continue to use it. I'm not sure wat your getting in act bellato but everytime I've tested the eflex here it has come up at 73%. Link to comment Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 12d Posted 23/04/13 08:45 PM Share Posted 23/04/13 08:45 PM Kroozin, your issue was not long after converting to e85. Chances are the ethanol loosened up sort and crud in your fuel system and blocked and damaged pump and injectors and filter. When you first convert to e85 you should change fuel filter at bare minimum after the first tank. The spot around exhaust tip could of simply been tune related. But spot around exhaust tip in no way indicated 100% a poorly running car or bad fuel.Interesting though that you've tested it at a consistent 73%. That's smack bang in the middle of the caltex summer/winter mix.Sort/spot = soot.Damn iPhone!! Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m Gender: Male Location: Adelaide Posted 23/04/13 09:29 PM Share Posted 23/04/13 09:29 PM Higher united ethanol content would of just "loosened" up the crap that was already there faster As I have mentioned before I was using united e85 before half of this forum knew what it even was over 5 years ago across two vehicles and never one single issue ever Always change my peterol filter really frequently and that's it Its easy to blame a exsisting issue to e85 use but we all have our own opinions and at the end of the day it your choice Eflex users u have to understand that with fluctuating content % u get fluctuating AFR's Simple as that 1 Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 5m 15d Gender: Male Posted 23/04/13 10:47 PM Share Posted 23/04/13 10:47 PM (edited) United users need to understand the same as I have heard from users on this forum that Uniteds E85 is not always 85% even though United state it is.So from what I can gather the difference in the ethanol content with both Companys may just be the way users are testing it, and most are testing with test tubes.I agree with you on the fuel filters and change mine at each 10,000 klm service. Have you tested your eflex at all rednose? As mentioned its been tested between e60 and e80 here in the ACT. I'd imagine the tune would have to be backed off quite a bit to compensate for the change in ethanol content?I have tested it on many occasions but only with a test tube (which is not accurate as there is no way that you can take out human error) and I have seen 70 - 73 and on 1 occassion 77, but again AFR's were fine and the car drove fine.It has been on the same dyno multiple times and tune is always spot on.I also emailed caltex a few times and advised of guys reporting fluctuation in ethanol content to which Caltex replied that since introduction of the eflex they have only ever made 1 change that took the ethanol content up from 70 to 71.I will keep using eflex as it has served me well, but anyone that wishes to use this fuel needs to do their homework as just like most things in life there are pros and cons. Edited 23/04/13 11:14 PM by Dagabond Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 3m 12d Posted 23/04/13 10:58 PM Share Posted 23/04/13 10:58 PM Yea see a lower ethanol content that is still consistent would be fine, I'm just concerned that it fluctuates so much here. I might ask to see the tuner's specific data and what he does with his car. He might adjust his tune every month or so to account for changes in the mixThen might send Caltex an email and see what they say. Still 3 months away from being tuned so plenty of time to sort my chit out and decide to run it or not Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 9m 10d Gender: Male Location: Sydney Posted 23/04/13 11:07 PM Share Posted 23/04/13 11:07 PM Kroozin, your issue was not long after converting to e85. Chances are the ethanol loosened up sort and crud in your fuel system and blocked and damaged pump and injectors and filter. When you first convert to e85 you should change fuel filter at bare minimum after the first tank. The spot around exhaust tip could of simply been tune related. But spot around exhaust tip in no way indicated 100% a poorly running car or bad fuel.I'd been running eflex for nearly a year before switching to the e85.Fuel filter gets done every 10000kms...Wat soot around the exhaust pipe? Link to comment Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 12d Posted 23/04/13 11:10 PM Share Posted 23/04/13 11:10 PM Rednose, caltex are telling you fibs. It's common knowledge that caltex change their ethanol content in winter and in summer. In winter they take ethanol out to aid cold starts. It's much more than a 1% difference year round. For them to tell you it's only ever changed 1% is a blatant lie.United e85 is very consistent. No it's not e85. It's actually closer to e90. But consistent. Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 9m 10d Gender: Male Location: Sydney Posted 23/04/13 11:14 PM Share Posted 23/04/13 11:14 PM More than likely though the batch of chit fuel was servo related.. the eflex at girraween gave up a vortex98 tank for there eflex where as the united I was using gave up there diesel tank.So in my case I'd day the fuel was contaminated by the chit in the servo tanks. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 4d Gender: Male Location: @ my laptop Posted 23/04/13 11:21 PM Share Posted 23/04/13 11:21 PM United ethanol content by my dyno gauge seems to be 83-85% even when my test tube shows over 90% 1 Link to comment Share on other sites More sharing options...
