Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 16y 11m 8d Gender: Male Location: Sydney Posted 16/01/13 10:00 AM Share Posted 16/01/13 10:00 AM How long does phase separation take to occur? "." Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 5m 3d Gender: Male Posted 16/01/13 10:03 AM Share Posted 16/01/13 10:03 AM Probably longer than 5 days which is how often I fill up so I should be ok, right? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 7m 23d Gender: Male Location: @ my laptop Posted 16/01/13 10:12 AM Share Posted 16/01/13 10:12 AM copy and paste answerCourtesy of Scott IrwinDid you know? In a 10% Ethanol Blend, it takes as little as 18 gallons of water in a 6,000 gallon tanks to cause Phase Separation. In a 2% blend it takes only 3.6 gallons to cause Phase SeparationWhat is ?phase separation?, and how do I deal with it?If significant amounts of water are present in a fuel tank with gasoline that contains ethanol, the water will be drawn into the fuel until the saturation point is reached for the three-component mixture of water + gasoline + ethanol. Beyond this level of water, phase separation could cause most of the ethanol and water to separate from the bulk fuel and drop to the bottom of the tank, leaving gasoline with a significantly reduced level of ethanol in the upper phase. If the lower phase of water and ethanol is large enough to reach the fuel inlet, it could be pumped directly to the engine and cause significant problems. Even if the ethanol water phase at the bottom of the tank is not drawn into the fuel inlet, the reduced ethanol level of the fuel reduces the octane rating by as much as 3 octane numbers, which could result in engine problems.The level at which phase separation can occur is determined by a number of variables, including the amount of ethanol, the composition of the fuel, the temperature of the environment and the presence of contaminants. It is very important (A) that the system is inspected for significant quantities of water in the tank before using gasoline with ethanol and (B) to limit exposure of the fuel tank to excess water. If phase separation has occurred, it is necessary to completely remove all free water from the system and replace the fuel before continuing operation. Otherwise, engine problems could occur. Link to comment Share on other sites More sharing options...
possum Donating Members 553 Member For: 15y 7m 28d Gender: Male Posted 16/01/13 10:25 AM Share Posted 16/01/13 10:25 AM (edited) based on that information with a blend of 85% ethanol, A full tank of fuel with the possibility of phase seperation occuring would require at least 1.734L of water in the tank for a sedan and 2.0655L for a ute.Any fuel with nearly 2l of water in it will cause problems Edited 16/01/13 10:29 AM by possum Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 5m 3d Gender: Male Posted 16/01/13 10:36 AM Share Posted 16/01/13 10:36 AM that's a alot of water to have in your fuel tank Link to comment Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 16y 11m 8d Gender: Male Location: Sydney Posted 16/01/13 10:36 AM Share Posted 16/01/13 10:36 AM Ok so unless you accidentally pour 2 litres of water into your tank you should be ok.Scare tactics gone mad."." 1 Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 7m 23d Gender: Male Location: @ my laptop Posted 16/01/13 10:47 AM Share Posted 16/01/13 10:47 AM The first thing you need to know about ethanol is that it is hygroscopic. Hygroscopic means that it will readily absorb moisture from its surroundings. In our case, the "surroundings" would be the atmosphere, and that atmosphere contains water. The higher the humidity, the greater the amount of water, and the greater the rate of water absorption by the ethanol. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 27d Gender: Male Location: Perth Posted 16/01/13 10:48 AM Share Posted 16/01/13 10:48 AM Air is water.........? Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 5m 3d Gender: Male Posted 16/01/13 10:51 AM Share Posted 16/01/13 10:51 AM But how long would it take to absorb 2L of water from the atmosphere? Link to comment Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 16y 11m 8d Gender: Male Location: Sydney Posted 16/01/13 10:52 AM Share Posted 16/01/13 10:52 AM (edited) But unless you leave your petrol cap off all the time and dont keep lids on your gerry cans you really haven't got a worry in the world. Good example was when Ricky's Ute sat at cms for 5 months with a full tank of E85 and once the motor was finally in it started and ran without issue."." Edited 16/01/13 10:53 AM by Vevapower Link to comment Share on other sites More sharing options...
