JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 7d Gender: Male Location: Adelaide Posted 09/01/13 12:18 AM Share Posted 09/01/13 12:18 AM that's what I mean .... I own this chit Mod ticket or not iam here bitches !!Now just to beable to post in locked threads lol Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/167/#findComment-1346834 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 15d Gender: Male Location: Perth Posted 09/01/13 12:20 AM Share Posted 09/01/13 12:20 AM I swear either fluffy wrote that post or you and her are spending that much time together you have become one person. Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/167/#findComment-1346836 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 7d Gender: Male Location: Adelaide Posted 09/01/13 12:30 AM Share Posted 09/01/13 12:30 AM Well we spend alot of time as one person Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/167/#findComment-1346840 Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 17y 4m 27d Gender: Male Location: Sydney Posted 09/01/13 01:08 AM Share Posted 09/01/13 01:08 AM So say a $2500 fuel system is money better spent than a $10000 engine if there is a lean out condition?I spent 3.5k on the fuel system but I have over engineered since day one.My set up:Pw twin railPw surgeTurbsmart FR 1200 regTeflon braid everywhere -6 &-810 micron mscn filterAero motive A1000 Siemens in tank1200 cc injectors"." 2 Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/167/#findComment-1346855 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 1m 18d Gender: Male Location: Sydney NSW Posted 09/01/13 04:56 AM Share Posted 09/01/13 04:56 AM Vevas system is pretty much the best way to go on these cars upto around 1000hp @ fly.The system Ive been making up for poeple of late is...Billet fuel rail (Plaz or AeroFlow)Plazmaman Billet tankAeromotive A1000 pump (or second 044 on my adapter mount)Turbosmart Reg (or Aeromotive) 1200hp rating minimum - #8 in & outFuel Lines-Surge to Pump #10 ( a must have to keep the pump from crapping itself)Out of pump (A1000) #8 into Y splitter #8 to twin #6Two #6 lines up to each end of railOne #8 line out of rail (centre) to Fuel Reg (#6 is fine for this side also.)One #6 line out of reg to Surge tank return ( #8 can also be used as the reg will have #8 outlets)Use Teflon braided lines with the correct fittings.Its also a good idea to fit a new OEM Ford filter, as they are fine with Effonal, and I prefer to use a NEW or low kay OEM intank pump, again Effonal is fine with them.The early Walbros are not Effonal approved, there is only ONE Walbro pump that is, and its hard to find, so for reliablitlity sake, a good OEM Ford pump is perfect, and a new OEM Ford sock filter.Remember that Ethonal is a very effective cleaner, so it will pull all the crud and debris from evey nook and cranny in the fuel system, so its a good idea to keep changing the main filter when you fist do the E85 conversion.Unfortunately its cleaning abillities have caused majority of issues with blocked lines ect, which is why poeple think its a corrosive fuel, its not when fitted to cars designed to use it... such as our cars running E10... more so NA falcons but you get the idea.I feel the rule of thumb is keep it simple, if your only going for 400kws then a simple system with ONE 750-1000hp pump & 80s or 1000cc injectors, keep all the OEM lines to the surge tank, just make sure the surgtank to pump line is E85 approved... The latest Plazmaman & ProcessWesst hoses are quoted as ok for E85 from what Im told.I hope no one is scared off from using E85, its such a dam good fuel, even the slightly up and down Eflex is awesome... we are so lucky to be able to drive up to a servo and fill up with what is basically super high octane race fuel, with large backing from major petroleum companies and out Government.You just have to know what level you want to take your motor to, and set it up accordinly.... do that and you wont have any issues... other than bald tyres and brown undies 2 Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/167/#findComment-1346919 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 1m 18d Gender: Male Location: Sydney NSW Posted 09/01/13 05:52 AM Share Posted 09/01/13 05:52 AM Also , I was just at MSC and they have a new E85 rated rubber push on hose available now, so that gives us a cheaper , usable hose rather than using Teflon braided hose... So easy push on fit and factory looking rubber hose, plus it's alot cheaper. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/167/#findComment-1346923 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 5m 19d Posted 09/01/13 06:16 AM Share Posted 09/01/13 06:16 AM Can you supply all this ??I have a process west surge tank and single 044 pump currently. Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/167/#findComment-1346930 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 20y Gender: Male Location: OZ Posted 09/01/13 06:37 AM Share Posted 09/01/13 06:37 AM Where are most mounting aftermarket regs. I've seen a number of different set-ups and most look average. The best I have seen is the 'headsex' style where an additional fitting was welded to a PW surge (and the usual return blocked) so the reg basically bolted on. Looked neat and out of sight of the boys in blue. Any other ideas for a neat fitment? Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/167/#findComment-1346938 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 1m 18d Gender: Male Location: Sydney NSW Posted 09/01/13 07:10 AM Share Posted 09/01/13 07:10 AM Can you supply all this ??I have a process west surge tank and single 044 pump currently.Yes but call or email me to discuss it as I dont like to do these "one size fits all" as you may prefer a different pump or lines ectToads, I like to have them within easy access and sight, its good to be able to monitor pressure while doing a dyno run, and make any quick allen key adjustments... but yeah out of sight would be prefered for stealth reasonsVevas set up looks very neat and kind of stealth... maybe he might throw a pic up? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/167/#findComment-1346954 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 20y Gender: Male Location: OZ Posted 09/01/13 07:44 AM Share Posted 09/01/13 07:44 AM Thanks RAPID. Has anyone got data on fuel temp? I can only imagine a big flow setup cycling through the surge is going to heat the fuel a fair bit....something I've wanted to do but never had the resources / donor car / motivation and/or time! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/77949-e85/page/167/#findComment-1346975 Share on other sites More sharing options...
