E85
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 7m 19d
So in tonys case the tuner has opted for less pressure but longer duration due to having head room with the injector.
Could u in theory run 4 pumps 200psi and 42lb injectors to 500rwkw ?
  • Member For: 16y 1m 29d
injector would sh*t itself if reg is not maaaaaasifff
also, you only have a small window that the injector could stay open due to the strokes, valves etc.
the 42lb injector would need to be fully open at max pressure (not sure at what point it would fall apart) for the longest time possible and still it prob wont be enough
Edited by Paulie2256
Yeh just a long shot lol think toads said 7bar max so 100psi , but iam onto something lol
Suppose it all comes down to timing or boost
Reduce the boost, reduce the duration and pressure needed
  • Moar Powar Babeh
  • Member For: 19y 3m 27d
In theory you can communism, but that didn't work either
This makes the 500 odd rwkw nizpro are getting off 1 o44 an incrediable feat of injector duration, rail pressure,and boost levels and not go lean !!!
Some would say mathamatically impossiable ?
<blockquote class='ipsBlockquote'data-author="Ralph Wiggum" data-cid="1346829" data-time="1357690171"><p>
<br />
In theory you can communism, but that didn't work either</p></blockquote>
It works on this forum
Zinggggggg lololol
