JVK Silver Donating Members 751 Member For: 19y 2m 5d Gender: Male Location: North West Hot Hell,VIC Posted 08/01/13 07:39 PM Share Posted 08/01/13 07:39 PM What size Jet ? Link to comment Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 16y 2m 14d Posted 08/01/13 09:22 PM Share Posted 08/01/13 09:22 PM (edited) If your injectors are seeing that pressure, that ain't cool. Most are only rated to 7 bar. I think he must be seeing that preasure else were. Edited 08/01/13 09:33 PM by CCCC Link to comment Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 16y 2m 14d Posted 08/01/13 09:35 PM Share Posted 08/01/13 09:35 PM With the twin pumps its about 110psi at idle :/Hey kosij, how you going mate, were you measuring that preasure from? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 27d Gender: Male Location: @ my laptop Posted 08/01/13 09:46 PM Share Posted 08/01/13 09:46 PM Some good technical knowledge being posted at the momment and starting to show that some fuel systems are not performing correctly 1 Link to comment Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 6m 13d Gender: Male Posted 08/01/13 09:49 PM Share Posted 08/01/13 09:49 PM (edited) With the twin pumps its about 110psi at idle :/Hey kosij, how you going mate, were you measuring that preasure from? As said above I bunged a sensor in the fuel line that feeds the rail! So just before the rail is where I get my pressure reading from! I only really use it as insurance to ensure both 044's are working. But it does display high numbers Edited 08/01/13 09:52 PM by Kosij Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 23d Gender: Male Location: Adelaide Posted 08/01/13 10:01 PM Share Posted 08/01/13 10:01 PM Piks bloke lets have a see what your seeing 1 Link to comment Share on other sites More sharing options...
f6mark Member 2,908 Member For: 14y 9d Gender: Male Posted 08/01/13 10:02 PM Share Posted 08/01/13 10:02 PM when I do united e85. ill be only be ues'n one 044 pump & 1000cc injectors. only look'n 400rwks. will I need to run to 044 pump's to get 400rwks.? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 27d Gender: Male Location: @ my laptop Posted 08/01/13 10:16 PM Share Posted 08/01/13 10:16 PM looking at Tony's results yesterday, if the fuel pressure reading is correct, then 1 pump is not keeping up, but plenty will argue 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 23d Gender: Male Location: Adelaide Posted 08/01/13 10:18 PM Share Posted 08/01/13 10:18 PM In tonys case would u be expecting to see 78psi at the rail across the run as a bare minimum mick ? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 27d Gender: Male Location: @ my laptop Posted 08/01/13 10:20 PM Share Posted 08/01/13 10:20 PM yes give or take a few psi based on gauge accuracy and just the way the regs work, but the fuel pressure should be following the boost curve Link to comment Share on other sites More sharing options...
