RAP1D Member Donating Members 3,739 Member For: 18y 9m 3d Gender: Male Location: Sydney NSW Posted 08/01/13 08:05 AM Share Posted 08/01/13 08:05 AM What fuel reg are you using?any boost referenced reg will see 78psi on that boost when base is set at 60psi, as Mick saidIt's fairly common to bump up rail pressure to give injectors a bit more flow on boost, usually a band aid fix until bigger injectors are fitted.Good to see another happy E85 convert! 1 Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 10m 1d Gender: Male Location: Sydney Posted 08/01/13 08:17 AM Share Posted 08/01/13 08:17 AM Yeah I thought they were a rising rate reg. or something like that 60psi + boost on top for total Link to comment Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 6m 12d Gender: Male Posted 08/01/13 08:27 AM Share Posted 08/01/13 08:27 AM Mine is twin 044's standard rail & reg gauge shows 125psi when cold in the morning and 105psi once warm but under WOT 100psi is maintained! I have 1000cc injectors!Gauge is mounted into the line feeding the rail. Link to comment Share on other sites More sharing options...
relentless xr6 Member 363 Member For: 14y 2m 19d Gender: Male Location: Sydney Posted 08/01/13 08:36 AM Share Posted 08/01/13 08:36 AM with e 85 should you be changing your oil a lot sooner?? Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 6m 6d Gender: Male Posted 08/01/13 08:39 AM Share Posted 08/01/13 08:39 AM <blockquote class='ipsBlockquote'data-author="relentless xr6" data-cid="1346558" data-time="1357634190"><p>with e 85 should you be changing your oil a lot sooner??</p></blockquote>I change at 10,000 an don't have a problem, tested and was advised I could easily get another 5,000 before it would need to be tested again.There are oils that are ethanol approved 1 Link to comment Share on other sites More sharing options...
tonyv EPC Member Donating Members 1,598 Member For: 16y 2m 19d Gender: Male Posted 08/01/13 08:52 AM Share Posted 08/01/13 08:52 AM stock fuel rail and reg with 1000cc kpm ev14's 2 Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 9m 3d Gender: Male Location: Sydney NSW Posted 08/01/13 08:53 AM Share Posted 08/01/13 08:53 AM Kosij, your gauge isn't set up correctly to read rail pressure, fuel pres gauge on a return style fuel system needs to be on the reg as the reg closes up under pressure to maintain constant pressure.Your changing pressure could be voltage drop across the pumps... Did you upgrade the wiring loom to suit the extra current draw from the second 044? It's common to see voltage fluctuations on our cars, 13-14 volts and this can have a huge effect in the fuel system and injectors. 1 Link to comment Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 6m 12d Gender: Male Posted 08/01/13 09:12 AM Share Posted 08/01/13 09:12 AM Yeah wiring to suit the twin 044's was addedI didnt think the gauge was set up correctly but it still shows me when there is a fuel issue, one 044 shat itself recently and it showed me so it's more of a gauge to show fuel pressure is normal.So do a I need an aftermarket reg to accurately monitor the pressure? 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 23d Gender: Male Location: Adelaide Posted 08/01/13 09:25 AM Share Posted 08/01/13 09:25 AM Drill bit Cheers 1 Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 7m 15d Gender: Male Location: OZ Posted 08/01/13 09:33 AM Share Posted 08/01/13 09:33 AM (edited) It should read 4 bar minus vacuum where you have it mounted! So ~48 psi at idle iirc Edited 08/01/13 09:38 AM by IH8TOADS 1 Link to comment Share on other sites More sharing options...
