E85
  • Waiting for the 1st N/A 12!
  • Member For: 17y 3d
Strange how my rapid cooler only gets to 42 and it started at 31. 11 degrees from bottom to the top of the run is more than exceptable IMO.
It was a 24 degree day on that run to.
From what I understand the big niz and the new spec plaz coolers are probably where it's at in terms of keep ok keeping temps down.
But let's not also forget about the importance of flow as well as cooling. No use have a cooler that cools awesomely but flows crap and vice versa.
Bang for buck it's still hard to beat the rapid cooler.
Mines worked great for almost 2 years now and supports just under 500 rear and several 10 sec passes as well.
My 2 cents.
Edited by Vevapower
  • Member For: 13y 6m 4d
Rapid cooler done me well, but the boost problems was a issue especially with a ba block! 18psi and the block don't like each other.
Just weird how now my boost is easier controlled same tuner same car different cooler!
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 8m 14d
Sorry Jet but my Rapid cooler is doing just fine making 430rwkw on 18psi and E85 havnt noticed any eat soak even doing back to back 3rd-4th power runs (private road)
Um I like rapid coolers ..... Did I miss something here ? Either way good numbers dude
So you have an intake temp gauge?
  • Member For: 16y 3m 21d
Nah mate but car pulls as hard every boot back to back. All I can say is 430 is pretty dam good on 18psi flat across rev range (pitlane dyno)
Jet sorry if I missed something just read gtexxed comment saying he would have got a better cooler if
He had the coin as if you had bagged the rapid cooler, sorry if you hadnt said such things.
Edited by ARVO
