JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 7m 19d Gender: Male Location: Adelaide Posted 30/10/12 10:33 AM Share Posted 30/10/12 10:33 AM um anywhoo c23 is where its at 119 octainegive that a bash if u can afford it Link to comment Share on other sites More sharing options...
Glouva1 Donating Members 654 Member For: 13y 6m 15d Gender: Male Location: Surrey Hills, Melbourne Posted 30/10/12 10:45 AM Share Posted 30/10/12 10:45 AM We've done at least a dozen now, the results are great with boosted engines but the long term problems are not yet known. E85 is like alcohol in many respects and does effect many plastics, rubbers, and mild steel with coatings. Later cars are designed to take E85 moreso. We are getting gains in the range of about 60-80 rwkW with similar mods to 98 in an engine with around 250-300 rwkW. A recent fg g6e made 383 rwkW with a high flow cat and boost pipes with ID 1000's and a big fuel pump on 16 psi. We went from 360 to 460 rwkW on a built BA on 20 psi before maxing up the 880 cc injectors. The issue mainly is supplying enough fuel. The other issue being what cylinder pressure a stock cylinder head can stand, I'm sure people will dispute this but our testing has found beyond 20 psi with optimal timing the heads are hard to keep on, I am aware of a number of tuners that are experiencing the same issue, unfortunately the torque generated with a good fuel and optimal timing that pushes the piston down is also trying to push the head off, a guy called Newton said, "for every action there island equal and opposite reaction". C'mon aftermarket industry we need an aftermarket head with a thicker deck so we can reliably run more boost with the ideal timing. As for quality, buy a tester and make sure then tank is empty of 98 before filling with E85.CheersJoelCompletely agree with you with the head issue. Aftermarket one would sell like hot cakes. Link to comment Share on other sites More sharing options...
XYZ Donating Members 1,171 Member For: 15y 4m 2d Posted 30/10/12 11:02 AM Share Posted 30/10/12 11:02 AM (edited) +2 on head.. I have lifted mine 3 times!! Edited 30/10/12 11:02 AM by XYZ Link to comment Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 16y 11m 8d Gender: Male Location: Sydney Posted 30/10/12 11:03 AM Share Posted 30/10/12 11:03 AM Even with 14mm studs? Link to comment Share on other sites More sharing options...
Glouva1 Donating Members 654 Member For: 13y 6m 15d Gender: Male Location: Surrey Hills, Melbourne Posted 30/10/12 11:09 AM Share Posted 30/10/12 11:09 AM Yep. Link to comment Share on other sites More sharing options...
CMEFRY New Member 12 Member For: 12y 5m 21d Posted 30/10/12 11:09 AM Share Posted 30/10/12 11:09 AM Veva u need a motor like mine coz it ATOMIC hahaha Link to comment Share on other sites More sharing options...
XYZ Donating Members 1,171 Member For: 15y 4m 2d Posted 30/10/12 11:10 AM Share Posted 30/10/12 11:10 AM 2 x Atomic 1 x ARP2000'sNow using a multi layer gasket and a new alloy based 12mm stud that torque rated to 130ft lb... Don't think this head is going anywhere anymore... Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 3m Posted 30/10/12 11:14 AM Share Posted 30/10/12 11:14 AM How many guys use eflex or the like all day every day? Given it is like 50c a litre cheaper than 98 from the pump that's like $30 a tank cheaper. So surely the increase in fuel consumption would be countered by the cheaper price and you get more power? Or is that much worse on fuel consumption that its not worth using it every day? Sorry if these questions got asked earlier, don't remember reading it Link to comment Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 16y 11m 8d Gender: Male Location: Sydney Posted 30/10/12 11:34 AM Share Posted 30/10/12 11:34 AM Veva u need a motor like mine coz it ATOMIC hahahaWhy would I want 2 of them. Ha ha Link to comment Share on other sites More sharing options...
XR6menace BANNED Banned 1,462 Member For: 17y 8m 22d Gender: Not Telling Location: banned Posted 30/10/12 11:42 AM Share Posted 30/10/12 11:42 AM I just want a definative answer on what fuel filter to run with it... because I know from previous misadventures the eflex blocked up 2 x Z373's within 200km's..anyone got a pic of their filters ?pleasecheers. Link to comment Share on other sites More sharing options...
