How Long Do These Turbos Last
camdawgs
  • Banned
  • Banned
  • Member For: 14y 4m 12d
Stop being pedantic ! An FG xr6 turbo can do it with tune only so why can't an F6 that allegedly makes 310 fwkw stock ? you're at the madam tonight.
FG F6 will crack 300rwkw with a tune only easy as pie !
Edited by RHR
over quoting
  • Banned
  • Member For: 14y 2m 1d
It is simply incorrect that XR6 turbos have "close to rwkw as per fwkw". Rab, your BF would not have made 250rwkw stock unless it was some sort of freak (or previously tuned) - not even close.
A dyno might say it did, but then they are never accurate and you go from one to the next and the figures change dramatically.
As for the OP saying whether he will have trouble with 300rwkw down the line, I would say the answer is most like yes (whether turbo, trannie, engine) - its just a matter of how long!
  • Banned
  • Banned
I don't have BF mate, I have a 2010 50th anny FG ! made 250 stock as a rock and they mostly all do this more or less !
F6 injectors, venom cat and V8 airbox seen over 300rwkw and as far as I can remember, the F6 has these parts stock and a bigger turbo ?? It is a BF typhoon we're talking about isn't it which has 270fwkw same as ford said the FG xr6t had so I am assuming with the bigger turbo, bigger injectors, that it should make 300rwkw with just a tune ??
Could be way off , I wish someone with a BF typhoon who's done just a tune would clarify !
Edited by RHR
OVER QUOTING USE ADD REPLY BUTTON!!!
  • Banned
  • Banned
Well I apologise, I assumed the BF typhoon would heve been a capable unit straight out of the box, obviously not as capable as the FG out of the box !
Please pardon my ignorance ! :hang:
  • Member For: 17y 7m 29d
That's fine but for future reference don't argue the point when your only going on assumption and don't actually know.
Trying to correct people that are infact correct only makes you look silly.
