Kosij Donating Members 2,045 Member For: 13y 8m 23d Gender: Male Posted 26/11/11 09:13 AM Share Posted 26/11/11 09:13 AM just had my xr6t tuned and I don't understand the letters and numbers in the box so I was wondering if someone could explain the reading for me.. also do you think the power drop off is the valve springs? Link to comment https://www.fordxr6turbo.com/forum/topic/77920-can-someone-help-explain-my-dyno-sheet/ Share on other sites More sharing options...
F1PERFORMANCE Donating Members 104 Member For: 16y 1m 20d Gender: Male Location: VIC Posted 26/11/11 11:03 AM Share Posted 26/11/11 11:03 AM RR = Ramp rate 15kph secIT = inlet tempAT = Air temp BP =barometric pressusreRH - Relative Humidity Link to comment https://www.fordxr6turbo.com/forum/topic/77920-can-someone-help-explain-my-dyno-sheet/#findComment-1163269 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 8m 23d Gender: Male Posted 26/11/11 11:21 AM Author Share Posted 26/11/11 11:21 AM Cheers, Link to comment https://www.fordxr6turbo.com/forum/topic/77920-can-someone-help-explain-my-dyno-sheet/#findComment-1163270 Share on other sites More sharing options...
Boganspeed Will do skids for food Silver Donating Members 1,177 Member For: 13y 5m 29d Gender: Male Location: Perth SOR Posted 27/11/11 12:17 AM Share Posted 27/11/11 12:17 AM Being a 3rd gear run, I assume because their dyno won't spin fast enough to run it up in fourth, does that mean the reading will be artificially high ?Or is it like MPH at the drags, no matter what gearing you have MPH pretty much determines your power. Link to comment https://www.fordxr6turbo.com/forum/topic/77920-can-someone-help-explain-my-dyno-sheet/#findComment-1163331 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m 7d Gender: Male Location: Far north queensland Posted 27/11/11 04:19 AM Share Posted 27/11/11 04:19 AM 3rd will read a little higher Link to comment https://www.fordxr6turbo.com/forum/topic/77920-can-someone-help-explain-my-dyno-sheet/#findComment-1163374 Share on other sites More sharing options...
45T-XR Donating Members 417 Member For: 18y 1m 27d Gender: Male Location: Gladstone, Queensland Posted 27/11/11 04:56 AM Share Posted 27/11/11 04:56 AM (edited) Is it ZF auto?, if it is that's normal to run them up in 3rd gear Edited 27/11/11 04:56 AM by 45T-XR Link to comment https://www.fordxr6turbo.com/forum/topic/77920-can-someone-help-explain-my-dyno-sheet/#findComment-1163389 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 6d Gender: Male Location: @ my laptop Posted 27/11/11 05:04 AM Share Posted 27/11/11 05:04 AM we normally run them in 4th but have found it is able to get a higher reading when run in 3rd Link to comment https://www.fordxr6turbo.com/forum/topic/77920-can-someone-help-explain-my-dyno-sheet/#findComment-1163394 Share on other sites More sharing options...
The Outsider Donating Members 1,205 Member For: 13y 11m 18d Gender: Male Location: Burwood, NSW Posted 27/11/11 06:03 AM Share Posted 27/11/11 06:03 AM whats the difference in power figures from 3rd to 4th? Link to comment https://www.fordxr6turbo.com/forum/topic/77920-can-someone-help-explain-my-dyno-sheet/#findComment-1163415 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 6d Gender: Male Location: @ my laptop Posted 27/11/11 07:25 AM Share Posted 27/11/11 07:25 AM I'm guessing the numbers as I can't remember exactly but it may have been 5-10 rwkw and is greater the less power the car makes Link to comment https://www.fordxr6turbo.com/forum/topic/77920-can-someone-help-explain-my-dyno-sheet/#findComment-1163433 Share on other sites More sharing options...
Guest XR09 Guests Posted 27/11/11 07:53 AM Share Posted 27/11/11 07:53 AM Thought forth was the closest to one to one and the truest reading. Link to comment https://www.fordxr6turbo.com/forum/topic/77920-can-someone-help-explain-my-dyno-sheet/#findComment-1163441 Share on other sites More sharing options...
