Intake
salv
  • Member For: 14y 3m 20d
The V8 box and snork is maxed out at 350rwkw. This was proven on f6mark's car by two tune shops - separate dynos.
It doesn't matter if you drill out or letter box mod the box as the panel filter - including K&N - does not flow enough air. Bottom line, you can get past 500rwhp with the crossover but not with the factory box - dyno proven fact. You'll need to run a large conical filter and this case, he's running a growler. No doubt others on the market would achieve the same results.
I beg to differ, my utes making 400KW at the wheels factory cross over and V8 airbox with K&N filter, dyno'd with the box shut as it runs on the street. Dyno sheet to prove it, so unless the dyno is out by 50KW I have a feeling you are wrong. Many things contribute to power output but the airbox being maxed at 350KW aint true. In saying that running a free flowing turbo side inlet would be much less of a restriction I agree.
  • Carnage on the Garage Floor
  • Member For: 14y 7m 29d
Sounds like Qld tuners are full of crap then. His car actually hit the wall at 360rwkw, not 350, so I didn't have that 100% correct. So we have two respected shops - not affiliated - both identifiying the same restriction which once resolved, enabled the tune to be taken past 500rwhp. I don't doubt your car is making 400 mate but again, I can only go off facts concering his car and the tuners concerned.
If the factory airbox can support 400rwkw then I would suggest nobody would bother changing them. The reality is, plenty do.
  • Member For: 17y 7m 14d
There have been a few F6's that have made over 350 with the V8 box the standout would be that silver one that ran a 10.8 I think it was with one.
Don't think restriction is the main reason people swap them for turboside intakes.
  • Resident idiot.
Agree not all change them for the restriction. To be honest it never even crossed my mind at the time. I wanted a bit more spool noise. That said now I want less lol. I put the muffler thing back in and it is so much better.
Can't do that with a turbo side..
  • 2 weeks later...
  • Member For: 13y 9m 4d
If you just want a bit more noise and a few extra hp. Cut a hole or two in the bottom of your box and get a k and n panel filter to suit. Should give you a bit more noise bling and also give you a couple more seat of the pants hp. Save your money that setup would be good for upto 330rwkw or do what these boys are doing with the v8 air box and typhoon snorkel etc
  • Member For: 14y 4m 12d
this may be common knowledge but couldn't find an answer, I'm assuming better heat shielding from engine bay temps is with a aluminum air box rather than a plastic/fibreglass one?
