  • Member For: 13y 7m 13d
  On 21/11/2011 at 3:48 AM, PhilMeUp said:
You can buy the BA Premium calipers brand new from MTQ (look them up on whitepages.com.au). Trade price is around $200 each caliper (not sure what retail price is). The part numbers are B862-381 (LHS) and B862-382 (RHS).
Problem is that is without the mounting brackets. If someone can get the brackets then buying the calipers new locally is very viable.
The mounting brackets are different to the standard ones - I've already checked and compared (got Premiums on my girlfriend's taxi).
I saw that you also had the Brembo's now on your own taxi after taking these off with 18's. How much room have you got between the caliper and the inside of the rim? I saw your measurements from caliper to spokes, but after the other. What would be even better is knowing the centre of hub to furthest point of caliper, as all wheels are different depending on offset and construction etc.
  • Member For: 19y 7m 23d
at the ford forums , no1 has found a 17 inch rim that will clear 4 or 6 pot bembos , the minimum is 18" even then the range is not so great!
Not good for me then. Only found one who was running a 17"x4.5" rim with these that fitted. I dare say not much of the caliper would be within the rim being so narrow! Wonder if the 4 pot would fit with a 330 rotor then? Depending if there is anything stopping the caliper going further inboard as can make custom mounts no problem.
The 6 pot ones actually look a little slimmer due to the smaller pistons I guess. I wonder if there is a bit more clearance with those? Looking at philmeup post on another thread with his 6 pot with 18's, appears to be just over 1/2" of clearance to the inside of the rim which is all you would need in the radius to clear 17's depending on the wheel brand, offset and if a reverse rim or not.
Would so love to know the centre of hub to outside of caliper on the 4 and 6 pot. Would make checking wheel clearance for anyone looking for a upgrade that much easier. Could measure these maybe while still mounted from the centre of cap to the outside of the caliper.
Edited by Gojeep
im sure that these measurements have been done be4 in the wheels and tyres section.
I will be putting my brembos on this weekend if all goes to plan and will do measurements then
I have 6pot fronts and they have less clearance than the 4 pot fronts.
  • 4 weeks later...
Thanks for all the help on here but decided in the end to take the cheaper way out and fit some new calipers I had for years sitting on the shelf.
I made a conversion to fit the SRT8 Brembo 4 piston calipers.
These are all the pieces I came up with to do the conversion.
The brackets I made bolt to the back of the knuckle
They are big!
The rotors I used with a matching 5x4.5"pcd are from a Ford Territory Turbo and measure 340mm/13.5" and 32mm thick.
They fit nicely behind my 17" rims too.
You can see more detail if you want in my FB album.
https://www.facebook.com/media/set/?set=a.10150405995576898.360741.665551897&type=1&l=57769b6d76
