  • Member For: 18y 11m 23d
  On 26/11/2011 at 2:09 AM, LUXJET said:
With a stronger shaft won't other stuff then break? Also is it possible to leave the torque restriction on for drive but remove it for performance mode?
That's the way it goes, if you have enough power and have traction you normally break things.
Torque management can not be changed via modes
  • Member For: 15y 8m 3d
That's what I was told after mine went. I replaced mine with a heat treated standard one rather than billet.. A lot cheaper to replace the shaft than the other components of the ZF.
  • Carnage on the Garage Floor
  • Member For: 15y 9d
What are we talking (ballpark) in dollars to replace an input shaft Mick?
Haven't had to do one yet but I would expect possibly 3500 to 5000 for a rebuild using a new shaft. I think off hand, and happy to be corrected, that Nizpro's input shaft maybe $1800 on it's own, Monsta Torque uses a different one and builds a good box using it
  • HOON
  • Member For: 15y 2m 5d
FG input shaft?
