Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 10d Gender: Male Location: Gold Coast Posted 09/12/11 12:12 AM Share Posted 09/12/11 12:12 AM Lots will probably disagree, but that looks awesome IMO Dre. TBH, I Iiked the look of your stock height photo better compared to when you first dropped it. Now though, it looks better. It might be a tradie thing (I'm anal about panel gaps and things being square etc) but the gaps around the wheel arches look uniform now so it has improved the lines. The XYZ's do actually go lower than the XA pedders so they might have more before shockie bumpstop. That aside, I'll probably go about 5mm higher than than your current height, so good to know that has improved the ride. Cheers, Bomber. Link to comment https://www.fordxr6turbo.com/forum/topic/77761-review-on-coilovers/page/4/#findComment-1167458 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 10d Gender: Male Location: Gold Coast Posted 09/12/11 12:14 AM Share Posted 09/12/11 12:14 AM On 09/12/2011 at 12:02 AM, Ralph Wiggum said: Dre, have a look at your front and rear control arms,I bet they are level our slightly higher than levelWas told by my suspension shop that level is ideal yeah? Link to comment https://www.fordxr6turbo.com/forum/topic/77761-review-on-coilovers/page/4/#findComment-1167460 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 28d Gender: Male Location: Perth Posted 09/12/11 12:40 AM Share Posted 09/12/11 12:40 AM I run mine BA at a similar hieght too Dre's (around 335F 345R Gaurd to centre.) This puts the front arms level and the rears just above level. This means a better roll centre, Fugall bump steer from the front and Enough squat in the rear too maintain traction without looking 4wd spec. Once the arms get past level (ie the outside end of the arm is higher than the inside) as soon as you get ay movement in the suspension the track becomes narrower and you get a small amount of bump steer in the front end. Makes the car drive like ARSE IMHO Link to comment https://www.fordxr6turbo.com/forum/topic/77761-review-on-coilovers/page/4/#findComment-1167464 Share on other sites More sharing options...
TRA1NR Pitlane Member Donating Members 2,886 Member For: 18y 20d Gender: Male Location: Pakenham, Victoria Posted 09/12/11 12:50 AM Share Posted 09/12/11 12:50 AM Mine are almost dead level at the rear, have not had a look at the front. Link to comment https://www.fordxr6turbo.com/forum/topic/77761-review-on-coilovers/page/4/#findComment-1167465 Share on other sites More sharing options...
wa g6et Member 657 Member For: 13y 11m 18d Gender: Male Location: Perth NOR Posted 09/12/11 02:51 AM Share Posted 09/12/11 02:51 AM (edited) On 09/12/2011 at 12:40 AM, Ralph Wiggum said: I run mine BA at a similar hieght too Dre's (around 335F 345R Gaurd to centre.) This puts the front arms level and the rears just above level. This means a better roll centre, Fugall bump steer from the front and Enough squat in the rear too maintain traction without looking 4wd spec. Once the arms get past level (ie the outside end of the arm is higher than the inside) as soon as you get ay movement in the suspension the track becomes narrower and you get a small amount of bump steer in the front end. Makes the car drive like ARSE IMHO Mine is at about the same height too. Spot on about the reasons to be at this height, roll centre, keep front bump steer to a minimum and some height in the rear for it to squat and get power down better. It's all about the suspension geomentry, screw around with it too much just for looks and risk crappy handling. Edited 09/12/11 02:52 AM by wa g6et 1 Link to comment https://www.fordxr6turbo.com/forum/topic/77761-review-on-coilovers/page/4/#findComment-1167490 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 10d Gender: Male Location: Gold Coast Posted 09/12/11 02:52 AM Share Posted 09/12/11 02:52 AM yep, pretty exactly what I was told. It will tick both boxes. Make it look a bit tougher but improve handling and ride by having the geometry spot on. The whole slammed and negative camber crap just so you turn the front wheels is rubbish IMO. Eveyone to their own though. Link to comment https://www.fordxr6turbo.com/forum/topic/77761-review-on-coilovers/page/4/#findComment-1167491 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 28d Gender: Male Location: Perth Posted 09/12/11 02:53 AM Share Posted 09/12/11 02:53 AM On 09/12/2011 at 12:14 AM, Bomber said: Was told by my suspension shop that level is ideal yeah?Thats what I was implying mate I find having the rest slightly higher than level (10mm or so) give a good amount of squat under power and keeps the tire contact patch at max. On 09/12/2011 at 2:52 AM, Bomber said: yep, pretty exactly what I was told. It will tick both boxes. Make it look a bit tougher but improve handling and ride by having the geometry spot on. The whole slammed and negative camber crap just so you turn the front wheels is rubbish IMO. Eveyone to their own though.^ ZOMG it looks killaaaa tho. Stance4life Link to comment https://www.fordxr6turbo.com/forum/topic/77761-review-on-coilovers/page/4/#findComment-1167492 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 10d Gender: Male Location: Gold Coast Posted 09/12/11 03:12 AM Share Posted 09/12/11 03:12 AM lol. Link to comment https://www.fordxr6turbo.com/forum/topic/77761-review-on-coilovers/page/4/#findComment-1167503 Share on other sites More sharing options...
