greenskinned monster Member 7 Member For: 16y 6m 18d Posted 12/11/11 01:44 PM Share Posted 12/11/11 01:44 PM Hey All, I dont know if anyone out there has come across this, but when you get your wheel alignment done be sure to tell the guys doing it to check the front crossmember mounting bolts BEFORE they do the alignment. Ford made a bit of a F*&k up with the B series (not that they will admit it. The FG has a steel crossmember instead of an ally one!) and put an alloy crossmember in the car. Now over time due to torsional differences between the ally crossmember and the steel chassis its bolted too, these bolts work loose, totally screwing up your wheel alignment. Now if the tyre shop dont know to check these bolts and just do the alignment with them loose, the minute you drive the car away from the shop, the alignment changes due to the whole assembly moving around. Its something that happens over time, and you dont notice it as it doesnt get loose to the point of clunking or anything,but it does make the car wander slightly,and the steering sloppy in corners, and obviously wears your tyres out. A friend of mine made me aware of it as he had tyres wearing out every 10k, and after a local tyre shop here contacting FPV, they advised of this very issue. mine get tightened every 10k when the wheel alignment is done, and I tell you what you will be amazed at the difference. I believe they get done up F.T. .. just a bit of usefull info as not all tyre shops know about this issue. Link to comment https://www.fordxr6turbo.com/forum/topic/77751-front-crossmember-in-b-series-falcons/ Share on other sites More sharing options...
Gasman Ford Nub Member 412 Member For: 14y 1m 5d Gender: Male Location: Gold Coast Posted 13/11/11 12:36 AM Share Posted 13/11/11 12:36 AM probably why after my last wheel alignment it got worse... Link to comment https://www.fordxr6turbo.com/forum/topic/77751-front-crossmember-in-b-series-falcons/#findComment-1159171 Share on other sites More sharing options...
