  • 2 months later...
  • Member For: 14y 3m 13d
  On 11/04/2012 at 11:37 AM, James xr6fgturboute said:
Hey mate what year is it ?
It's a May 2011 build mate.
  On 12/04/2012 at 1:11 PM, Sydneyxr6t said:
Tim
well done nice sensible mods and great result.
What torque are you making?
cheers
Armando
Thanks Armando. Not sure on the amount of torque I'll find out though
  • 1 month later...
Just an update I'm getting the ute retuned fairly soon. Since the last tune I have done a rapid systems 4" turbo side intake. Next I'll be doing ID1000 Injectors, Walbro 300lph fuel pump and the tune. I'm wondering if I'm on the right track with this setup? Will most likely be doing further mods later on down the track (turbo, full exhaust etc)
  • Like 2
  • 3 months later...
Update, a lot of things have happened the past few months.. Blew the oil pump gears when I missed a gear and redlined the car. Got a new Atomic Oil Pump in there so never have to worry about that again. Other than that I got a retune done and mods now include:
- ID1000 Injectors
- 4" Rapid Turbo Side
- Rapid Intercooler kit
- Walbro 400lph pump
- 4" dump into 3.5" Xforce Exhaust
- 12psi actuator
- Turbo port/flapper mod
Car is now making a strong 317rwkw tuned by Hi-Torque. Turbo has been making lots of bearing noises and I believe its on its way out so bought a GTX3582r which will go in hopefully in the next few weeks.
  • Like 2
  • Member For: 13y 9m 23d
looks good, should pull some decent figures with that GTX bolted in. I'd be looking at throwing in a surge tank with the kinda power you're gonna make though. regardless should be lots of fun
  • Like 2
  • Member For: 14y 7m 5d
Gee hi-torque dyno must understate or your turbo's pretty buggered because that's a lot of supporting mods for only 317rwkw. What boost you running?
With a gtx and surge + 044 you'll see around about 380rwkw surely
Hi Torque uses a mainline dyno and it's still fairly new (only a year old I believe) so I've been told my car would read 330rwkw+ on other dynos/dyno dynamics etc. Not too worried about the number anyway the tune feels great and I did a lot of chopping at the cruise 4 charity at QR the other day.
Next mods are GTX turbo then gonna wack in a mal wood opt 3+ clutch, mal wood short shifter and atomic valve springs. Surge + 044 will be done a little later down the track. Should see close to 400 with this setup
  • Like 2
  • Member For: 16y 5m 16d
Sounds like you got it all worked out, my only suggestion if shooting for 400kw maybe a malwood stage 5 clutch if you intend on giving it a hiding, the 3+ is great and rated for just over 400 I know but still something to think about
  • Like 2
