xr6bfv Member 17 Member For: 16y 5m 27d Gender: Male Location: Central Coast / St Leonards Posted 10/11/11 08:39 AM Share Posted 10/11/11 08:39 AM hey guys, currently im running 360rwkw in my typhoon but am only running a stock cooler with stock pipes,everything seems fine but just wanna know will I start to break hoses when summer rolls round or will the intercooler not be able to produce cold enough with the summer and this much power?like I said during the winter its been fine.help would be great cheers Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 11m Gender: Male Location: Vic Posted 10/11/11 08:48 AM Share Posted 10/11/11 08:48 AM I wanna get my car on your dyno so I can be in the 400 club!Seriously that us way, way, past it's limits. Pipes won't break, but your motor will. Link to comment Share on other sites More sharing options...
T6EGO Donating Members 91 Member For: 14y 9m 17d Gender: Male Posted 10/11/11 09:43 AM Share Posted 10/11/11 09:43 AM Just to put your setup into perspective for you. Mick from Pitlane advised me to upgrade my typhoon cooler which I had on my xr6 even though I was only after 300rwkw. So 360. Boy your intake temps would be hot hot hot. Link to comment Share on other sites More sharing options...
xr6bfv Member 17 Member For: 16y 5m 27d Gender: Male Location: Central Coast / St Leonards Posted 21/11/11 08:31 AM Author Share Posted 21/11/11 08:31 AM yeah I have noticed that my engine is hot when I turn it off, but temp is showing only 1/4 all the time,is there a intercooler that you guys found is best, and price?not looking for more power, but will I need a retune?cheers fellas Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 11m Gender: Male Location: Vic Posted 21/11/11 09:15 AM Share Posted 21/11/11 09:15 AM Are you planning to push for more power? Because that will be factor. Staying where you are, a $700 hdi will be fine. Nizpro/ plazmaman/ process west are all good. Plazmaman is probably best value. Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 3m 25d Gender: Male Location: Far north queensland Posted 21/11/11 10:32 AM Share Posted 21/11/11 10:32 AM you should get a touch up tune if you get another cooler - same power with lower intake temps is better for engine Link to comment Share on other sites More sharing options...
xr6bfv Member 17 Member For: 16y 5m 27d Gender: Male Location: Central Coast / St Leonards Posted 23/11/11 08:37 AM Author Share Posted 23/11/11 08:37 AM cheers fellas Link to comment Share on other sites More sharing options...
orangeute338 Suspended 260 Member For: 16y 6m 22d Gender: Male Posted 25/11/11 10:52 AM Share Posted 25/11/11 10:52 AM ecu can adjust if you just get a bolt on cooler and use the stock piping you will be right...think about it all you are doing is cooling the air coming into the motor. in winter the air is cooler then summer so the ecu has to change to suit the air temp...its only when you change the flow rate eg bigger piping less drag quicker spool is when you would need a retune...all that will happen in summer is you wont make 360kw you might make it for 10seconds then you will prob make 260kw because your cooler will be heat soaked, the ecu will see high intake temps and pull the timing out to suit the intake temps...engine temp on the gauge has nothing to do with intake temps, the intake temps spike up under boosta cooler that uses all the stock piping would be the best bet...water injection is another option to keep the temps down under boost 1 Link to comment Share on other sites More sharing options...
MX Dave Donating Members 545 Member For: 13y 10m 15d Gender: Male Posted 05/02/12 11:12 PM Share Posted 05/02/12 11:12 PM Keep in mind flow rate can change with a different cooler. Especially over the stock cooler I'd Defiantely check afrs. That's a lot of power for the stock unit :/ Link to comment Share on other sites More sharing options...
