The 400 Mission
djqc
  • Member For: 19y 6m 16d
Air pressure from the compressor wheel flows through the wastegate solenoid (controlled by the PCM) and then to the nipple of the wastegate actuator which acts in a diaphram and pushes the actuator rod out to open the wastegate flapper.
The PCM controls te solenoid cycle time, so 100% means no air applied to the actuator rod and 0% means full boost pressure applied to the rod and the gate will open wide.
The actuator spring tension needs to be sufficient enough to ensure the gate stays closed at 100% duty cycle.....if not boost will be bled off. If the actuator spring tension is too high then boost pressure will not be sufficient enough to open the gate and hence boost pressure above desired will be experienced.
The PCM can be used to control boost in both closed loop and open loop....but that's another tutorial.
The fact that the boost graph isn't flat probably means insufficient actuator tension for the desired boost pressure. If you log duty cycle and see that it's high, this will prove the point!
  • Member For: 13y 7m 21d
So what is the consequences say between using a 8lb actuator compared to a 12lb. It probably depends on power and boost you are after and I assume.
Tuners have different opinions on this. Mine says for my requirements, FG std turbo and 300rwkw, the 8lb was what he uses and controls the boost better with the PCM, not really sure what this means though, was kind of hoping for a better explaination of this. Is it then diificult to control boost under 12psi if using a 12lb actuator. I have a low boost tune in my SCT tuner for use with 95ron would this still be possible with the 12lb actuator.
Does this mean for 400rwkw with the bigger turbo 8lb wouldn't be enough, and 12 or higher would be needed.
Sorry Luke if this is bit off your thread but thought some technical infromation for us novices might help understand what goes on.
If you have an 8psi actuator then 8psi is generally the lowest boost you can run. Depending Inge set up 8psi actuators are perfect for 11 to say 15 psi applications. 15psi to 17psi I would use a 12psi actuator and above 17psi I would go a 14psi actuator. Quality of the port job, exhaust backpressure and whether you an bleed air to the top of the gate in an external application all affect the ideal actuator / gate spring tension.
Edit yeah, 8lb is too weak when you're trying to push decent boost with a turbine housing that has decent backpressure.....such as the one in question.
Edited by IH8TOADS
Thanks heaps, makes better sense now. The turbo size/ back pressure starts to come into play with the actuator size when you up the anti.
I really appreciate you helping shead a bit of light on this issue. Not always easy with mine being my first turbo. Starting to get a better handle on these cars now.
Pretty sure Luke there is an answer to your issue amoungst all this. Lots of people who really want to help you get what you want from your car.
WA G6ET those wheels look awesome do they come in 19x8.5 19x10's?
My axis hiros are too big for the rear at 10.5" lookin for some new wheels
Just in 19x8 as per original FPV GT 5th Anniversary or GT-E/F6E
  • Waiting for the 1st N/A 12!
  • Member For: 16y 11m 13d
Was your 425 tune on E85 or pump?
Either way great power, how much extra did you make on E85?
How much is E85?
425 tune was on 98 but ran up on a DD Dyno!
E85 is where I get it Caltex is anywhere from 1.10 - 1.20 per litre!
Made about 50 rwkws on E85
  • Member For: 16y 8m 2d
Hey vevapower what size rims you got ate they 19's? Also what tyres you running with all your power? Also a Bummer about the input shaft mate.
