Rota Wheels, Who's Got Them And What Size's Ba-Bf
smXR6
  • Member For: 16y 9m 3d
Yep will fit, will be good safe rear fitment too.
  • Replies 345
9.5+20 is 3mm less on the inside than stock, so will be fine.
  • Member For: 17y 29d
What is the limit of reduction of inside distance you would generally be able to get away with on the front and rear of a B series? Does it change much with rim diameter?
  • Member For: 14y 8m 8d
Ok I have another question, will rota grids clear 6 piston brembo's? Are 6 piston calipers and 4 piston calipers pretty much the same size?
Also which color do people think would look best, hyper black or bronze? My ute is black btw
Bronze for something interesting to look at!
  • Member For: 11y 5m 16d
I stole this photo off "Boosted Falcon" and based my calculations off it,.
It's running 18x10 +17 up front and 18x10 +15 on the rear.
I used the offset calculator on 1010TIRES.COM and came up with the following.
I want to run 18x9.5 Rota P45R2's and they're available as +12 and +20 and I'm aiming for good fitment.
Based off the calculator if I run the +20's on the front I would get 3mm more clearance on the inside and would retract 9mm from the outside compared to the 10" +17. If I had +20 I'd get 11mm more on the inside and retract 1mm from the outter.
For the rear I'd defintely go for the +12's since they would retract only 3mm from the outside and give me 9mm more on the inner, this is going off the wheels in this photo! Should look okay I think!
Couldn't get the uploader to work so here is a link!
http://img.photobucket.com/albums/v204/oneredED/f2a459f7.jpg
