Musky Member 7 Member For: 14y 9m 22d Posted 26/10/11 02:36 AM Share Posted 26/10/11 02:36 AM Hey guys,I'm wanting to lower the rear of my tray back as it was converted by previous owner to a one tonner and looks stupid high.At this point I've not much money to my name and so proceeded on getting a quotes on lowering the rear, one mech told me it'd cost me $200 and all he'd do was remove leaves from the spring pack. Not a bad price but if that's all he was gonna do I thought I'd have a crack at doing it myself. Is it pretty straight forward? Anything I should be wary of before I do it?From what I've read removing a couple of the bottom leaves is the best way to go until desired height is reached, correct?Also, one of the bottom leaves that I'm wanting to remove has a bracket welded to it (attached pic), which to me doesnt look like its doing anything, any thoughts on whether its safe to remove this leaf?Cheers for any help Link to comment Share on other sites More sharing options...
Brods Member 433 Member For: 14y 6m 23d Gender: Male Posted 26/10/11 02:48 AM Share Posted 26/10/11 02:48 AM Just get some lowering blocks, or reset your springs for 350. Link to comment Share on other sites More sharing options...
j.d Member 1,222 Member For: 14y 6m 24d Gender: Male Location: Eastern Suburbs, Melbourne Posted 26/10/11 03:31 AM Share Posted 26/10/11 03:31 AM Wouldn't the weight tolerance be different if you take leafs out? Wouldn't it weaken, with less leafs? Link to comment Share on other sites More sharing options...
Tobey Awesome... Member 407 Member For: 14y 7m 16d Gender: Male Posted 26/10/11 03:48 AM Share Posted 26/10/11 03:48 AM XR6 only has about 3 leaves in the pack. However it has another 3 spacers in the pack to compensate within the saddles.If you remove a couple of leaves you will have to replace them with something or there is no way of holding the diff in place. Best just to get the leaves reset. Dont use lowering blocks as they foul on the rim. Link to comment Share on other sites More sharing options...
Musky Member 7 Member For: 14y 9m 22d Posted 27/10/11 01:16 AM Author Share Posted 27/10/11 01:16 AM (edited) Wouldn't the weight tolerance be different if you take leafs out? Wouldn't it weaken, with less leafs?Yes the weight tolerance would be lower. But I dont need one tonne, I barely carry anything and I never tow so its not an issue.Just get some lowering blocks, or reset your springs for 350.Yeah I got a quote for resetting them from Pedders for $260 which isnt too bad. I guess that's the road I'll be going down, I just wanted to see if I could do it and save some coin. The missus doesnt like me spending money on the car...... Edited 27/10/11 01:17 AM by Musky Link to comment Share on other sites More sharing options...
