g6e-psi Member 46 Member For: 13y 7m 15d Gender: Male Location: melbourne Posted 24/10/11 11:45 PM Share Posted 24/10/11 11:45 PM Hi pple got a problem put a external wastgate on my fg g6et and a boost tap in jectors etc the problem is on the dyno the boost hits 17 psi the drops to 5 psi can any one help would b apreciated as its on the rollers now cheers Link to comment https://www.fordxr6turbo.com/forum/topic/77517-boost-18psi-then-drops-down-to-8psi/ Share on other sites More sharing options...
Tobey Awesome... Member 407 Member For: 14y 11m Gender: Male Posted 25/10/11 12:59 AM Share Posted 25/10/11 12:59 AM (edited) Does it use the standard actuator? As these are too weak, they cant stay shut when on boost... For 17psi you should have at least a 15psi actuator in there.EDIT: Using external wastegate wont have an actuator duh...Check the joiner that goes onto the throttle body, these are known for leaking... Edited 25/10/11 01:03 AM by Tobey Link to comment https://www.fordxr6turbo.com/forum/topic/77517-boost-18psi-then-drops-down-to-8psi/#findComment-1153408 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 4m 18d Gender: Male Location: Christchurch, New Zealand Posted 25/10/11 02:07 AM Share Posted 25/10/11 02:07 AM What is the external gates spring pressure? Do you need to adjust it first. Link to comment https://www.fordxr6turbo.com/forum/topic/77517-boost-18psi-then-drops-down-to-8psi/#findComment-1153420 Share on other sites More sharing options...
g6e-psi Member 46 Member For: 13y 7m 15d Gender: Male Location: melbourne Posted 25/10/11 02:36 AM Author Share Posted 25/10/11 02:36 AM Ill see if it leaks thanx Link to comment https://www.fordxr6turbo.com/forum/topic/77517-boost-18psi-then-drops-down-to-8psi/#findComment-1153424 Share on other sites More sharing options...
g6e-psi Member 46 Member For: 13y 7m 15d Gender: Male Location: melbourne Posted 25/10/11 02:17 PM Author Share Posted 25/10/11 02:17 PM Hi pple got a problem put a external wastgate on my fg g6et and a boost tap injectors etc the problem is, on the dyno the boost hits 17 psi then drops to 5 psi as the revs build up?!?!?!?! can any one help???? would b appreciated as its on the rollers now cheers :banghead: Link to comment https://www.fordxr6turbo.com/forum/topic/77517-boost-18psi-then-drops-down-to-8psi/#findComment-1153589 Share on other sites More sharing options...
MexicanBatman G666E Turbo!!! Member 1,008 Member For: 15y 4m 20d Gender: Male Posted 25/10/11 03:46 PM Share Posted 25/10/11 03:46 PM Can't help other than to add your tuner should know what's going on and advising youWhat turbo are you using? Link to comment https://www.fordxr6turbo.com/forum/topic/77517-boost-18psi-then-drops-down-to-8psi/#findComment-1153597 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 13d Gender: Male Location: Perth Posted 25/10/11 11:02 PM Share Posted 25/10/11 11:02 PM 1 thread is enough.What other mods are done too the car besides the gate? What cat/dump is it running? Link to comment https://www.fordxr6turbo.com/forum/topic/77517-boost-18psi-then-drops-down-to-8psi/#findComment-1153620 Share on other sites More sharing options...
g6e-psi Member 46 Member For: 13y 7m 15d Gender: Male Location: melbourne Posted 26/10/11 12:11 AM Author Share Posted 26/10/11 12:11 AM put a stage 2 cooler 1000cc injectors 60ml external waste gate serge tank with 2 044's and a 4inch dump into 3.5inch exhaust with hi flow cat.stock turbo.all I know bout the gate is got the two springs I think 15psi Link to comment https://www.fordxr6turbo.com/forum/topic/77517-boost-18psi-then-drops-down-to-8psi/#findComment-1153643 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 13d Gender: Male Location: Perth Posted 26/10/11 12:21 AM Share Posted 26/10/11 12:21 AM got any pics of how the gates positioned? Whos tuning it and with what software? Link to comment https://www.fordxr6turbo.com/forum/topic/77517-boost-18psi-then-drops-down-to-8psi/#findComment-1153646 Share on other sites More sharing options...
g6e-psi Member 46 Member For: 13y 7m 15d Gender: Male Location: melbourne Posted 26/10/11 12:28 AM Author Share Posted 26/10/11 12:28 AM using sct to tune Link to comment https://www.fordxr6turbo.com/forum/topic/77517-boost-18psi-then-drops-down-to-8psi/#findComment-1153648 Share on other sites More sharing options...
