  • Member For: 13y 8m 27d
Just wondering.. If I mix the decent nulon octaine booster - claiming to boost fuel octaine by 5 octaine points, with 91 unleaded, will that be safe for use in an xr6T, and would the quality be just as good as 95 octaine?
  • G666E Turbo!!!
  • Member For: 15y 5m 4d
No and 5 points is not 5 Ron
Might be passable if you used 95 and it was for limited easy use but I wouldn't if you have a high hp tune
  • Silver Donating Members
  • Member For: 17y 1m 10d
If its std yeah but I still would'nt, best octane booster ive ever found & used not to mention cheaper is toulene & it will bump ya octane levels up complete points.
Are ya using this because you have to or you want to use it?
  • I see a red door and I want to paint it black
  • Member For: 15y 7m 26d
Matt - I seem to recall you car is stock. It will run on any petrol out of the pump. Best value I found was running 98 all the time. Once you have run a couple of tanks of 98 disconnect your battery and put your high beams on for 10 mins. Reconnect you battery and keep running 98 from then on. ECU will learn and you will get better economy and more powaah.
  • Member For: 14y 5m 18d
What is it then?
And I'm no chemist, but if the octane booster does what it's supposed to, what's the problem using it?
Not sure if you're being serious but where'd you learn this?
Which part Brett? my guess is the part about the battery and ecu
1: disconnecting batery and high beams on. This is just a quick and easy way to drain power from your car, high beams drain it pretty quick, only really need a 30 seconds, not harm in 10 mins though just to be sure.
2: ecu learning. The ecu will learn how much timing to pull from poor fuel and your driving style and slowly adapt over time to suit. After you reconnect the battery, flog the car if you want power and responsiveness or baby it on the hiway if you want fuel economy
The zf gearboxes also learn your driving style and adapt to suit.
  • Member For: 17y 7m 12d
Ok for a short while, but will foul plugs over time. My tuner recommends Wynns race formula octane boost which will mimick 98 when added to 95- no pinging, full power etc. He tried all brands available, on the dyno and that's his preference. I use it occasionally, but run 'pure' fuel most times to avoid plug fouling.
  • 4 weeks later...
Hmm ok, dunno why they'd use volatile memory when it's that easy to wipe all your settings but it's pretty possible I guess.
Oh I can see how an ECU would make minute corrections based on data gathered previously over time to help with things like knocking and whatever, but noticeably increasing power? How many Watts/Kilowatts are we talking here? :/
