Bov For G6Et Want The Dose Flutter Sound
tommyk1987
  • You've changed man....
  • Member For: 14y 2m 3d
Said it a million times.
The tutututu noise is when all the compressed air passes back through the turbo and out the intake after throttle body closes. A bov, in correct position, prevents this from happening. To a point.
  • Member For: 17y 9m 5d
Airbox (small pipe off turbo with pod on it) with heaps of boost and no bov and you'll get your turkeys.
  • Banned
  • Banned
  • Member For: 14y 5m 18d
If tutut is what's happening , its the pressurised air passing back over the turbine blades trying to stall the turbo. sounds good but the Bov idea is to stop this and reduce lag by keep the turbo spinning.
A bov with a tight spring wont do its job properly and too lose will lose boost.
  • Pitlane Member
  • Member For: 17y 10m 1d
Take the hose out between the bov and the crossover and block the ends up with chair stoppers. You will get minimal flutter at standard boost levels anyway but this is how you achieve it, mine is fairly loud now, but also has cooler pipes and a replacement intake pipe
  • Member For: 15y 1m 12d
Its not the turbine being effected its the compressor due to the intake air going backwards through it and stalling the turbo which makes the noise out the intake as stainless said. Otherwise the reduce lag bit and bov info is correct.
  • G666E Turbo!!!
  • Member For: 15y 1m 14d
This would probably suck for a manual, but in an auto there is no issues during gearshifts as turbo stays on the boil
No dose in my car unless you lift your foot, throttle stays open when foot is flat to floor so no lag on gearshifts
Manuals FTL LOL
