  • Member For: 13y 9m
ok guys I took the heat shilding off yesterday to check on the bolts to find one is not there anymore (one of the 4 bolts that hold the turbo onto the manafold
so what id like to know is what should I replace them bolts with or how can I get new ones .... without costing me heaps... Iv brought locktight to stop them from comeing out again much help your be good
https://www.fordxr6turbo.com/forum/topic/77464-turbo-bolts/
why wont lock tight work if its high temp / high vibration proof ?? sorry I dont know as I need to get this fixed asap as im driveing the car from melb to ad next weekend
https://www.fordxr6turbo.com/forum/topic/77464-turbo-bolts/#findComment-1151860
  • Moar Powar Babeh
  • Member For: 19y 7m 29d
method to remove loctited bolts is too heat them. It softens the loctite. Exhaust system gets hot. You can probably work out the rest. Use the Atomic Posilocks or Nord lock. the exhaust NEEDS mechanic locking devices for the bolts
https://www.fordxr6turbo.com/forum/topic/77464-turbo-bolts/#findComment-1151868
